racehoss' 1985 4Runner Build-Up Thread
Old Nov 29, 2011 | 01:06 PM
  #121
racehoss's Avatar
Happy Thanksgiving, Hoss...... Sorry bout the 'drama'.... still loving the rig~!
Back at ya brutha.
I've got it all fixed now. But I'm waiting for my paycheck to order the High Steer kit and see if we can make that work with such a low lift. My buddy that is helping me used to crawl with Marlin and says he's put high steer on a first gen pickup with 42" boggers and NO LIFT.
We'll see. Oh, ordering the 4:70 gears for the transfer case too. That will help with the death dry hops on the rocks.
Old Jan 28, 2012 | 02:56 PM
  #122
racehoss's Avatar
About to do high steer with small lift so I'll try to document it with detail because it's needed here. 2.25 lift Old Man Emu. With stock shock locations.
Old Jan 28, 2012 | 06:50 PM
  #123
ChefYota4x4's Avatar
NICE! Gonna take pics and do a write up? ...........Or, rather, "DONE, here it is"??? lol.
Hope you're well, Hoss!
Old Jan 30, 2012 | 05:13 AM
  #124
Boomtacoma01's Avatar
Thats going to be tough to do. Good luck
Old Feb 10, 2012 | 11:49 AM
  #125
liveoffroad's Avatar
Originally Posted by no1clipsmyclaws
Yea I'm having this same problem. I have 33x12.5 BFG Muds on my 85 4runner. Not sure how high my lift is since I bought it with it but I don't really want to go higher. I popped 2 tires before I figured out what was happening. I grinded that pinch down pretty good but my tire is now rubbing pretty much on the firewall and the lowest part of the fender. It doesn't look like cutting the fender down will make much of a difference, and I don't really want to move my axle forward because of the job it will be. If you find an easy solution to this I'd love to know! And I will let you know what I end up doing if I do it before you!
had the same problem when i was running 33x12.50s. I did a cheap fix by taking the springs off and having a shop drill some new holes in the springs, moving the axle forward 3/4". (i tried drilling them myself at first but they ain't kiddin' when they call it "hardened steel"). 3/4" wasn't enough to mess with the stock steering configuration but got me more than enough clearance for the 33s!
Old Mar 5, 2012 | 03:49 PM
  #126
racehoss's Avatar
It's on the lift at landcruiser specialists. I'm moving the axle forward an inch with relocation plates from 4crawler. Got all new calipers and rotors as well as booster and master cylinder. We should be ale to get the all pro hy steer to work. Crossing fingers. I'll try to snap pictures while in progress but my lift time is very limited. Got my t case built with 4:70 gears so that should help from dry hopping the ledges again. Next up is my on board air then lockers.
Old Apr 5, 2012 | 01:03 PM
  #127
racehoss's Avatar
Ok the high steer is on but it looks like the pitman arm is too close to the leaf spring and I can't use a straight one. Has anyone been successful bending one or does someone sell a 1 inch drop? http://db.tt/dvmjTonC
Old Apr 5, 2012 | 01:12 PM
  #128
Dayummmmmm, .....where you been, Hoss????? lol....
Wish I had info on that.... I would ask Wabbit, Zuk or Mike at Marlin, .... they've GOT to have an answer, ya know?
Old May 5, 2012 | 10:24 AM
  #129
racehoss's Avatar
Welded the bumpstop extensions.
Would like some advice on fabricating a spare tire mount to the roll bar. I've seen a few rolling around but didn't get the details.
Old May 5, 2012 | 10:26 AM
  #130
racehoss's Avatar
Why aren't my pictures uploading?
Old May 5, 2012 | 10:28 AM
  #131
racehoss's Avatar
http://db.tt/6jZEgacA
Old May 5, 2012 | 10:29 AM
  #132
racehoss's Avatar
Bumpstop extensions
Old May 5, 2012 | 10:30 AM
  #133
racehoss's Avatar
http://db.tt/SxP2EQE8
Old May 5, 2012 | 10:35 AM
  #134
racehoss's Avatar
Just got this but I'm the worst at electrical stuff. I'm going to try and tackle the install. Where do yall suggest I hook it to electrical power? I was thinking about getting one of those sea something fuse boxes with 6 or so fuses. Is that what I need to hook directly to the battery then hook accessories like air compressor, fog lights, etc to????
http://db.tt/H6lF4gLp
Old May 5, 2012 | 10:47 AM
  #135
racehoss's Avatar
Forgot to show y'all my buddies misfortune. He's alright and already rewelding a new roof on. http://db.tt/DxVhACLj
64-Hurricane
Nov 14, 2008 05:41 AM
ravencr
Nov 18, 2007 06:25 PM
Hayes
Apr 11, 2007 07:48 PM
Sporin
Mar 21, 2003 08:39 AM
