racehoss' 1985 4Runner Build-Up Thread
Old Oct 20, 2011 | 07:21 PM
  #101
racehoss's Avatar
Originally Posted by hrt4me
Did you ever get your steering figured out? I could sure use some tips with my own '85 T4R and about 2" of lift, similar to yours...
I still have stock steering. After the springs got broken in the steering seems better. It's still kind of marshmellowy and the turning radius is poor but drivable. I bought a drop draglink but haven't installed it. High steer is the ultimate way to go and I'm sure I will figure that out soon enough.
My main problem now is my front tires both rub the fender well closest to the fire wall when a side compresses up. I think I'm going to trim the fender and body pinch welds about two inches.
Old Oct 20, 2011 | 07:24 PM
  #102
gary_the_4runner's Avatar
4crawler sells the plates that go under your leaf springs and relocates your axle forward a little bit. That pesky pinch weld hinders all of us.
Old Oct 20, 2011 | 07:34 PM
  #103
racehoss's Avatar
Originally Posted by gary_the_4runner
NICE, what a transformation! im loving the cruiser wheels with the pizza cutters!
You don't rub your front tires on the back of the fender well by the door hinge when compressed?
Old Oct 20, 2011 | 07:44 PM
  #104
racehoss's Avatar
I've been looking at that area and think just trimming it with a grinder and saws all is the easiest and best way because it doesn't affect the construction of the body and those relocation plates open a can of all other things like extending drive shaft and steering linkages etc.
Old Oct 20, 2011 | 09:36 PM
  #105
My driver side rubs real good fully compressed, but that's because I'm 275 lbs. Most people will cut it out I like front mudflaps when I'm on the road though so I keep bending it back and bolting em in
Old Oct 21, 2011 | 03:21 PM
  #106
hrt4me's Avatar
Originally Posted by racehoss
Finally got the A/C blowing ice cold!! I replaced the compressor, dryer, a couple hoses, idler bearing and thought it was good to go but then noticed the expansion valve was permanently shut so I bought and installed a new one. Now it blows 45 degrees when it's 105 outside. Pretty damn good. Thanks to Mr. Freeze, David peacock, in Austin for performing the surgery on my rig. Highly recommend his services if you live in central Texas.
How I wish you were closer to DFW because I sure could use some tips on my own A/C on my '85 T4R; it was cold six weeks ago, but it's gradually gotten warmer, and I don't really know where to start...
I would also love to see how you mounted your Warn M8000...
... and I could use some pointers on my steering and brakes...
Old Oct 22, 2011 | 02:32 PM
  #107
racehoss's Avatar
Took her out for the first real time and the first big ledge I came to, I shattered a burifield. Couldn't steer for awhile because it was binding so bad. It was crappy. Time for upgrades.
Old Oct 24, 2011 | 12:49 PM
  #108
racehoss's Avatar
Looking for a birfield and a little help putting it in.
Old Oct 24, 2011 | 02:19 PM
  #109
ChefYota4x4's Avatar
Best wishes on the hunt!(for birf's and hands to help! lol)
Sorry to hear that, btw.... but I couldn't help but chuckle when I read, "It was crappy"....hahahaha.... SO SIMPLY AND TRULY PUT!
Old Oct 26, 2011 | 12:21 PM
  #110
racehoss's Avatar
Pics of wheeltoberfest before I messed up my front axle.
Old Oct 26, 2011 | 12:23 PM
  #111
racehoss's Avatar
Why aren't any of my old photos showing up? Chef?
Old Oct 27, 2011 | 08:11 PM
  #112
Terrys87's Avatar
Glad to see you are getting to enjoy your build. Sorry to hear about the break down.
On the pics.Are you using Photobucket? I have seen mine occasionally not showing up and then later on they will. I havent figured it out myself.
Old Oct 27, 2011 | 10:14 PM
  #113
Outsane's Avatar
thats good lookin rig in the dirt!
nice sliders
Old Nov 7, 2011 | 01:36 PM
  #114
racehoss's Avatar
Just ordered the bigger front calipers from an 88 v6 4runner. I also got the vented front rotors. My question is about the master cylinder and booster. Do I need a new booster when I upgrade to the bigger 1 inch bore master cylinder?
Old Nov 18, 2011 | 12:48 AM
  #115
racehoss's Avatar
Here's how you break a birfield.
http://youtu.be/WBGaOzdff6k
Old Nov 22, 2011 | 05:39 AM
  #116
no1clipsmyclaws's Avatar
Old Nov 22, 2011 | 11:23 AM
  #117
1985runner's Avatar
No you dont need a new booster, i'm running vented rotos and v6 calipers with an IFS rear axle, with the stock 85 booster and the v6 MC, so far its working fine.
I actually ran v6 calipers with the stock 85 rear axle and 85 MC/booster for awhile and the brakes worked fine.
Old Nov 22, 2011 | 01:17 PM
  #118
1985runner's Avatar
Also i forgot to ask, how is your 4runner on 33s with 4/10 gearing? Do you like your 33/10.5/r15 KM2's, or do you wish you went with 33/9.5/r15 KM2s.
Old Nov 23, 2011 | 09:34 PM
  #119
Happy Thanksgiving, Hoss...... Sorry bout the 'drama'.... still loving the rig~!
Old Nov 29, 2011 | 01:02 PM
  #120
racehoss's Avatar
I like the 10.5s I wish they made 11.5 so I could fit them on my stock steel wheels. I'm running around town with 20lbs and it's like driving on marshmellows.
