Pair of 85 4Runners
Old Nov 27, 2017 | 07:43 PM
v8turbo's Avatar
Pair of 85 4Runners
Two 1985 4Runners - Building them for my 7 and 9 year old boys. Should be done by the time they are able to drive.....
Old Nov 27, 2017 | 07:47 PM
v8turbo's Avatar
Some parts along the way so far..... 22RE Performance Stage 3. and yes... Marlin knows me....
Old Nov 27, 2017 | 07:58 PM
v8turbo's Avatar
2nd Build Parts round 1.
Old Nov 27, 2017 | 09:34 PM
Kolton5543's Avatar
Pics or it ain't actually happening
Old Nov 27, 2017 | 09:36 PM
Kolton5543's Avatar
Never mind. I guess I got impatient. Took em all a long time load.
Old Nov 27, 2017 | 10:10 PM
RAD4Runner's Avatar
Sexy!
I think this line, "...Building them for my 7 and 9 year old boys..." is just a good excuse for Dad to have his cool toys now. LOL!
Old Nov 28, 2017 | 07:26 AM
jakey poo's Avatar
Adopt me?!?!?!?!??!!? A lot of high quality components going into these builds, you've got some lucky boys!
Old Nov 28, 2017 | 07:40 AM
v8turbo's Avatar
Parts....
Some Parts and build pics. Gauge Cluster before rebuild. Clock from YodaJims Junk yard..... works ! Upgraded master cyl. New long travel front Driveshaft.
Old Nov 28, 2017 | 11:16 AM
Melrose 4r's Avatar
5 Year Member
Nice trucks!
But by the time the boys are ready to drive the black rims will have gone out of style, come back and gone out again so stick with chrome!
Old Nov 29, 2017 | 02:01 AM
coryc85's Avatar
Those are some nice 4runners and some lucky boys.
Old Nov 29, 2017 | 03:50 AM
muddpigg's Avatar
Don’t think i’ve Seen anyone build 2 at once. Like the electric distro block under front console. What is led display over plugs, lighter plugs with voltmeter between them?? Where did you mount it?
Old Nov 29, 2017 | 05:33 AM
SomedayJ's Avatar
Please, say this to me:
Old Nov 30, 2017 | 08:00 AM
thefishguy77's Avatar
You adopting?
Old Nov 30, 2017 | 07:05 PM
v8turbo's Avatar
Originally Posted by Melrose 4r
Nice trucks!
Just my luck
Old Nov 30, 2017 | 07:25 PM
v8turbo's Avatar
Actually i have 3 of them. Going to order the new Cummins 2.8 for the 3rd truck. That's gonna be mine......
https://cumminsengines.com/repower.aspx
Ok... So I use all Blue Sea Systems for electronics. From the boating world - water proof and tough. The panel and red switch you see are where the radio was. I used a Warn winch Zeon plastic cover... it fit perfectly, drilled a few holes and made it fit. Bit rough... but its bomber tough. The Disti block is under neath on the carpet. Clean. Everything is individually fused.
The red switch above --- thats for the dual battery system. It has 3 positions. Off... batts separated, On... both connected, Auto .. both charging. I leave it in Auto unless I am using the winch. When the motor is off and not charging... the batteries automatically separate . When you start.. they connect and charge. So... the Below deck panels.. One in front and one in back... both are wired to the AUX batt. So is the rear winch set up. When camping or Overlanding and hanging out... you can power all the good and still have a starting battery at full pop.
My buddy Matt owns https://www.offgrid4x4.com/ He has all the dual battery stuff / wiring. Cant do with out.
Parts I used -
Distribution block -
https://www.bluesea.com/products/502..._Bus_and_Cover
Below Deck Panel - Super Trick way to add power ports. USB and 12v Cig Plug. Surprised they have not exploded in our 4x4 world
https://www.bluesea.com/products/435...Mini_Voltmeter
Dual Battery System -
https://www.bluesea.com/products/762..._-_12V_DC_500A
Breaker you dont see to cut power to Disti Block
https://www.bluesea.com/products/718...ace_Mount_100A
Low Range Batt Box for Rear
http://www.lowrangeoffroad.com/optib...d-diy-obb.html
Switch to cut power to rear winch
https://www.bluesea.com/products/300...witch_with_AFD
Old Nov 30, 2017 | 07:37 PM
v8turbo's Avatar
This is how I have the Dual set up in my Tacoma. Use it all the time and wanted it in the 4Runners as well. Only way was to Put one battery in the back.
Old Nov 30, 2017 | 08:00 PM
v8turbo's Avatar
To answer the DM's as to why.....and how much..... I figure... all in.... Ill be about 20K each. But.... they will have a bad ass 85 straight axle fuel injected 5 speed. No one born past 1995 can drive a 5 speed so theft is not a problem... and by 2025 when the first one can drive... they will be so well built and not like anything the other kids roll with.
With all new drive train and updated electronics... these will be so fun and last forever. Besides.... in 2025 and 2027... how much is a new car gonna be? The car discussions at that time with the kiddos will have been solved for years and paid for. Plus I like to build trucks.
At least that's the logic I used to convince myself.
Plus - All my kids get a 4cyl 5 speed for the first car. Keeps all hands and feet busy. You cant just get in... Shift to D and Pin it...while texting.
Old Dec 1, 2017 | 07:04 AM
v8turbo's Avatar
Check this one out.... I sold it bone stock to a DR back east. He called me after a while and said..... "I love it and want to build it ..... what should I do?" I found him a shop and told them what parts to use..... They nailed it.
Old Dec 2, 2017 | 05:16 AM
AustinTaco's Avatar
I had to track down the info on the Dr's truck, and found your posts. Great builds on both.
Old Dec 2, 2017 | 05:20 AM
muddpigg's Avatar
I like the blue sea products. Had stopped by local boat store they had nothing as nice. Will check out asome other shops. Thanks for info!!
