Jloffermann 84 4runner build up
Old Aug 26, 2015 | 04:26 PM
user 82300's Avatar
Originally Posted by Terrys87
As long as I dont get any issues I never have pulled the drums back off. A Weber is so much easier to work with. Not sure if it will pass the California emissions test.
Lce performance makes a California approved carb for:
81-83 and 81-84 yr only (don't ask about the overlap it's what California have them they said haha)
I just want a 32/36 with manual carb. Plus if you or someone you know buys my Asian.... I can get a weber sooner lol.
Old Sep 2, 2015 | 04:43 PM
user 82300's Avatar
Hahaha wow! Got a funny autozone story....
I recently replaced both rear seals inner/out, bearings etc because on my bearings went out, took out the seal and got gear oil everywhere. I got everything from lceperformance and worked great....
I got my drums,shoes,and hardware etc from autozone though. Everything went great with install except my right rear kept basically not turning at all without using a pry bar on the studs. Figured maybe just drive a block or two because maybe everything was tight....
Wrong!!!
Burnt brake smell bad after only 3 min drive. Pulled over at house opened up both sides and everything looked same. I tear adjusted and cleaned, greased again and noticed when I tightened lugs drivers drum wouldn't spin.
The drum was so bad that pass or drivers side if I tighten with lug nuts it won't spin lol. Autozone is gonna swap though so hopefully it works.
Old Sep 5, 2015 | 05:23 PM
user 82300's Avatar
Rear brakes finally adjusted correctly and the bad rear drum replaced.
Craigslist flaker never showed up to buy my Asian carb so the weber dream will have to wait little longer. But did get her running better with help from a friend. Timing is just hair advanced but still having trouble hitting 70 on flat ground.
Carb is really good so far, float is tad high but...
Valves good,
Timing chain, dizzy good, plugs, wires,ign,coil etc...
Gears are 4:10 or 4:11 with half worn 31s. Think 60 is just the way it is?
Old Dec 21, 2015 | 09:41 PM
user 82300's Avatar
A lot has happened....
I removed the engine and replaced all the gaskets,
Heads, timing cover, front and rear main and removed all the smog components.
Word of advice never ever trust
Someone to do work you can haha.
P.s. I have a rebuilt Asian carb and 99.9% of California emissions components that passed smog for sale now
New inverted 22r lol. I had to really hammer down the oem oil pan, someone pried on it and bent it up... But a couple of brass blocks, punches and a tube of Toyota fipg and she looks sealed right up.
Old Dec 26, 2015 | 04:58 PM
  #25
84 yota dude's Avatar
No engine rebuild, just gaskets? Sweet 4runner man
Old Dec 26, 2015 | 07:42 PM
  #26
user 82300's Avatar
While ago I had it rebuilt and the compression was amazing afterwards. However the rear main started leaking and he didn't put a new front main seal and out a crazy oil pan cork gasket so it leaked oil in like 4 spots.... I don't know how he did such a nice machanical job but so crappy with gaskets. My neighbor helped me check mains, bearing and stuff and it was all great haha.
Plus I finaly removed the air pump, ac and the intake manifold to install the plates and plugs for a 100% conplete desmog.
All I got to do now is remove the front window chrome trim and sand some rust away.
Old Dec 26, 2015 | 11:52 PM
  #27
Awesome, I see. Lucky with the desmog in Cali!
Old Dec 27, 2015 | 02:51 PM
  #28
user 82300's Avatar
Gotta love military status and Idaho residency. Idaho doesn't know what smog is haha.
Old Dec 27, 2015 | 07:28 PM
  #29
Badass haha
Old Jan 10, 2016 | 04:36 PM
  #30
user 82300's Avatar
Badass haha
Well been couple weeks since any progress. Mostly becuase the rain and using my neighbors driveway.... Got the engine in and all that's left is:
Fuel line re-routing since I removed charcoal canister
Radiator and checking all coolant lines
Fixing a couple super old cracked out alternator wires
Then:
Remove window: and treat rust
Replace both front calipers, and brake booster and brake master cylinder
Then.... Drive it haha.
Old Jan 30, 2016 | 08:41 PM
  #31
user 82300's Avatar
Update
ZERO leaks after driving it around for few days. What a relief. Also....
I tore apart the whole dash to fix a switch issue and wow learned a lot about hidden bolts, short wires lol.
And.... Had a mouse that previously lived in my dash. Above the glove box is a big metal bar like a support structure. There was a big best, very old but big.
I didn't take pictures becuase just wanted to get it back together before wife got back and started asking questions haha
Old Dec 24, 2020 | 02:41 PM
  #32
user 82300's Avatar
huge update...
sitting on 35in MT tires, been driving/wheeling truck ever since. sometime in the past 3 months the truck was sitting and the junk alarm from the previous owner caused a melted spot in the drivers side in cab fuse panel. Anyone ever order a painless wireharness/fuseblock kit or have a source on a truck/4runner I can pull/buy the fuse panel from?
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
XtraCab
Apr 12, 2020 05:25 AM
toyoda8488
Jul 5, 2015 10:18 PM
