Bugzman's 1985 Pickup Build-Up Thread
Old Aug 31, 2011 | 09:20 AM
  #101
windedwalrus's Avatar
you might have to use a flat pitman arm to get the clearence you need. i think the high steer pitman arm is the same as a stock one.
Old Sep 4, 2011 | 02:02 AM
  #102
s2k_661's Avatar
Amazing build Bro!!
Old Sep 4, 2011 | 10:08 PM
  #103
1986yota4x4's Avatar
thats one nice 85 man, really clean, how hard was it to install the twin stick shifter? and what pin did you have to remove?
Old Sep 29, 2011 | 05:07 PM
  #104
Bugzman's Avatar
the hardest par to of the twin stick install was removing the t case from the truck. once you have it out its like the most basic thing to do. with trail gears kit they give you instructions with he kit, and it has pictures! super super easy. the pin you remove is the pin the locks the two shift rails together. this allows them to move independently and gives you a 2 low. which i have loved since the day i got it!
Old Sep 29, 2011 | 05:10 PM
  #105
Bugzman's Avatar
i have a couple videos that we got when i was in big bear. 2 of my buddys have Toyota's too. so you will see them in one of the videos.
http://vimeo.com/28748651
http://vimeo.com/28748806
http://vimeo.com/28705839
Old Oct 6, 2011 | 04:48 PM
  #106
Bugzman's Avatar
got my black steelies on. these are 15X9 alot better rim size for my future tires, which i fell are going to 33X10.5
Old Feb 8, 2012 | 01:17 PM
  #107
Bugzman's Avatar
its been a bit. but I havnt done much. Just added an On board air system, and made the rear bumper an air tank. and new tires. so her are some pics.
Old Feb 14, 2012 | 08:34 PM
  #108
jessamiah's Avatar
your onboard air is AWESOME!!! im pretty sure you know that though. ingenious
Old Feb 22, 2012 | 07:35 PM
  #109
Nine mile style's Avatar
badass build. what length are your front shackles?
Old May 2, 2012 | 08:05 AM
  #110
Bugzman's Avatar
wow its been a while Guess I should update this Baby.
got some new rear shocks and mounted them
Old May 2, 2012 | 10:44 AM
  #111
77camaroCIVICkiller's Avatar
awesome build bro. did you make the square drive shaft?
Old May 2, 2012 | 01:14 PM
  #112
Bugzman's Avatar
yes i did. I made it out of a 2.5 x2.5 inch trailer hitch matrerial and a 2x2x1/4 inside of that. works amazing
I also welded down the length of the slip part. and used a hand file to make it a very tight fit.
greased with wheel barring grease.
Old May 29, 2012 | 03:49 PM
  #113
gbruner's Avatar
What size tires are those?
Old May 30, 2012 | 07:53 AM
  #114
Bugzman's Avatar
33 10.5
Old Jun 9, 2014 | 04:39 PM
  #115
jcm151's Avatar
I saw some of your videos on youtube, then I found your build thread.. pretty cool! I was wondering about a bunch of the specs/components of your truck were! Thanks!
JCM
*edit* had to change that last sentence.. must have been half asleep
Old Jun 10, 2014 | 11:45 AM
  #116
Bugzman's Avatar
awesome, I hope you liked the videos. let me know what you need, and ill do my best.
Originally Posted by jcm151
I saw some of your videos on youtube, then I found your build thread.. pretty cool! I had wondering a bunch of the specs/components of your truck! Thanks!
JCM
Old Jun 11, 2014 | 07:31 PM
  #117
jcm151's Avatar
Sounds good, thank you.. I am locked up at this point with lunch boxes, but was debating the elocker route, or arb route.. Also I need sliders, bumpers, air, and a few other mods you did.. Finally in the contemplation stage of single 4.7 with dual shifter, or duals.. I have 4.88, so would be at like 90:1 with single.. My rig has the same tires, same amount of lift, and I don't want to flip it .. So do you think the 4.7 is a good starting point/mod for the price/time?
Thanks.
Old May 29, 2015 | 01:25 PM
  #118
Bugzman's Avatar
havn't updated here in a while, so what the heck.
stepped up to 35s
added in some bumpstops
went to vented rotors and v6 calipers.
and trying my hand at auto body and paint
Old May 29, 2015 | 04:01 PM
  #119
Ericcason92's Avatar
Cool truck man, Im gonna set mine up the same way.
Old May 31, 2015 | 09:00 AM
  #120
84 yota dude's Avatar
Cool to see you still have it!! How are the MTRs? I've heard good and bad things about them
