85 SR5 regular cab "street worthy"
Old Aug 2, 2012 | 10:37 PM
  #61
NIGHTMARE's Avatar
Talk about a PITA cleaning everything up! Thats just one side! This should bring you up to speed to where the truck sits now. Hopefully in a couple of days I will start going back together with it.
some of the new parts starting to come in
Old Aug 3, 2012 | 12:38 PM
  #62
4Nmissile's Avatar
Looks like it is coming along. That grill looks as brand new as you can get. Wanna trade for my old grill ?
Old Aug 3, 2012 | 01:16 PM
  #63
NIGHTMARE's Avatar
Thanks 4N, slowly but surely! And no thanks on the grill! I think I'll keep it
Old Aug 6, 2012 | 07:42 PM
  #64
msugoose's Avatar
Man, it looks like you are really making some progress on your rig. I have a million pics of a couple of builds but have not posted any. You got me fired up! I am coming to town this weekend and will grab you a gift bag full of stuff you need. Just text me and if I got it I will bring it. Tell the old man I said hey.
Old Aug 6, 2012 | 08:46 PM
  #65
NIGHTMARE's Avatar
Man thought you would never get on here again.. And I will tell him, still need everything we talked about. Getting the knuckles cleaned up ready to put back together. Hopefully she will be drive able by the weekend. That's the plan anyway. Been waiting on you to find your way back down south. I could use the hand in the shop as you know my dad never gets around here anymore
Old Aug 7, 2012 | 01:54 AM
  #66
gabriel j's Avatar
Lookin good
Old Aug 7, 2012 | 06:57 PM
  #67
msugoose's Avatar
I am planning on going to the local u pull it junk yard Sat. morning. If you are not working we should hook up and rape the place of some good stuff.
Old Aug 7, 2012 | 07:21 PM
  #68
NIGHTMARE's Avatar
Man, that's the plan for me! I'll be off Fri, Sat, and Sun.. Meet at my house 830? I'll have a tool bag ready to go
Old Aug 7, 2012 | 08:21 PM
  #69
msugoose's Avatar
Sounds good
Ill be there early sat if everything works out!
Old Aug 7, 2012 | 09:04 PM
  #70
BerHntr's Avatar
What are exactly are you looking for? If you're talking about pullapart, I was there saturday and there's not a whole lot in the way of toyotas
Old Aug 8, 2012 | 02:38 AM
  #71
NIGHTMARE's Avatar
Well, I need a ton of stuff and goose is just looking for any part that is better than what he has. Most of all, I need front 4.88 gears. That way I can drive this truck this weekend! The other parts are parts that I plan on buying new unless I find a used one in good shape.
I need some advice on the steering up front if I can ever get the pictures to load to bring the build back up to speed. Hopefully it wont be long and I can get them up.
Old Aug 8, 2012 | 06:45 AM
  #72
BerHntr's Avatar
I don't think you are going to have any luck on the 4.88's but there may be some odd and end pieces to be found. I think there's 3 2nd gen runners and a couple 2wd 2nd gen pickups.
Old Aug 8, 2012 | 08:09 AM
  #73
j.burton50's Avatar
coming along man. looks good. after rebuilding my front end i find that imma need to rebuild the rear also, and probably the transfer case before to long :/
Old Aug 8, 2012 | 01:13 PM
  #74
NIGHTMARE's Avatar
Ha, I may be doing the same thing.. I haven't pulled any plugs on them to check them. My pics finally loaded on photobucket. So this is where the question comes in. Do you think the steering box is far enough forward? Are the arms far enough apart? I can take more pics if need be?
tell me what you guys think
Old Aug 8, 2012 | 01:22 PM
  #75
socal85toyota's Avatar
Looks good 2 me My box sits right around there...just make sure the sector shaft nut is tight and its not going to push the pitman arm up(if it wasnt tightened) into the frame. keep it up!
Old Aug 8, 2012 | 02:41 PM
  #76
NIGHTMARE's Avatar
Thanks socal, nothing is tight at this point! I want to make sure it is all right before I start welding and bolting it for good just in case I have to take it back apart. There looks like there is plenty of room for the pitman are to clear. I'll be sure to double check before I weld it up. Gotta work tonight and Thursday so it will be friday night before I can get back on it. Hopefully I will find a set of gears so I will have it back on the road by next week. Not looking good on the front gears.
Old Aug 8, 2012 | 03:41 PM
  #77
IMO i would tighten the hell out of the pitman arm and then still figure its gonna move up 1/16-1/8". whats wrong with ur gears?
Old Aug 8, 2012 | 05:02 PM
  #78
NIGHTMARE's Avatar
It has 410s in it right now and running the 33 inch tires is killing the drivetrain! While it's apart I'm going to go ahead and put them in so I dont have to pull it apart again.
Old Aug 8, 2012 | 10:29 PM
  #79
j.burton50's Avatar
highsteers looking good from what i can tell. what leafs are you running out of curiousity. im trying to decide what setup i wanna try because my fronts are pretty much done and id like to see a highsteer conversion in my near future also.
Old Aug 8, 2012 | 11:22 PM
  #80
NIGHTMARE's Avatar
The PO put a 4 inch kit on the truck. He went the cheap route so the rear has blocks. He couldn't remember what brand the lift is though. It is working out pretty well so far. I've had fun with it. I'm just ready to get the truck back on the road! The steering should be near finished by Sat. Thats the plan anyways, but my luck nothing happens like it's supposed to. We will see.
