85 reg cab
Old Apr 23, 2017 | 07:33 PM
4x4YOTA's Avatar
85 reg cab
Got an 85 Toyota pickup 4x4 in trade for some welding labor on a co workers dump truck ane a tune up
Truck is a 85 base
22R
5spd
4.10s
Plans are:
35s
4.7 t-case gears
5.29 F/R
Spartan front
Spool rear
4" lift
Bumper F&R
Sliders
Winch
and all the extra goodies in between
Picture of how i got it
Old Apr 23, 2017 | 07:34 PM
4x4YOTA's Avatar
Dropped a 22R from a 86 2wd with 40k miles
Old Apr 23, 2017 | 07:35 PM
4x4YOTA's Avatar
Put some tires off my 82 on so i can get it mobile and cleaned her up
Old Apr 23, 2017 | 07:36 PM
4x4YOTA's Avatar
Picked up my 35s
35x12.5x15 BFG KM2s on 15x8 Pro Comp 51s
Old Apr 23, 2017 | 11:08 PM
rustED's Avatar
Looks like a nice solid truck, the new tires and wheels are really going to set it off! Sounds like you have a good plan for it, can't wait to see some more pics!
Old Apr 24, 2017 | 02:01 AM
dropzone's Avatar
Fossilized
Great Score!
Old Apr 24, 2017 | 02:09 PM
4x4YOTA's Avatar
Test fit the 35s
They clear the rear fine but the front is turned as far as it can go...
i ordered a drop hanger to move the axle forward as well as shackles for both front and rear
Old Apr 24, 2017 | 04:29 PM
dropzone's Avatar
Fossilized
just out of curiosity did you KM2's measure small? Mine are just a hair over 34
Old Apr 24, 2017 | 06:07 PM
rustED's Avatar
looks great! If you are moving the axel forward are you going to do cross over steering too, or just work with the stock push/pull steering?
Old Apr 24, 2017 | 06:29 PM
4x4YOTA's Avatar
Thank you
immediate plan is to move the axle forward 1.5" and use the stock push pull and just shorten the drag link to match and go crossover steering as soon as I find a IFS steering box
Old Apr 24, 2017 | 06:40 PM
4x4YOTA's Avatar
i haven't measured them yet but I will and let you know
Old Apr 25, 2017 | 08:47 AM
4x4YOTA's Avatar
More parts showed up
Old Apr 26, 2017 | 05:51 PM
4x4YOTA's Avatar
My favorite part of this build so far is getting all the new parts.
Lockers showed up
Old May 5, 2017 | 07:59 AM
bootscootboogie's Avatar
Looks like you get some snow your way. Surprised at how much rust isn't on it. Nice progress. How are you lifting it?
Old May 9, 2017 | 05:46 PM
4x4YOTA's Avatar
Not sure how I am going to lift it for now but in the long run I would like to go all pro springs or possible 3link front 4link rear
Old May 9, 2017 | 06:15 PM
Since you can weld a lot of folks will recommend 63s in the rear. I've seen video of people using them and they flex so crazy. The rears up front flex good too. I have read that the trail gear front spring hanger will lift your front because of its design. I like following threads where dudes do their own fabrication, it's interesting
Old May 10, 2017 | 07:03 PM
4x4YOTA's Avatar
I am am going to do my own welding but will save time and use pre made brackets/tabs since I don't have a torch or drill press.
the TG drop hanger does a some height but not much,it drops 1" but in reality only lifts the truck .5". But helps with steering box clearance with the ifs steering box.
i have 2 sets of rears I want to use to make a front pack but just need time to get to the junk yard for some chevy springs if I go that route then I would use ruff stuff hangers to help keep it low.
but mostly want to do all I can to prevent having to cut up the clean sheet metal.
Old May 28, 2017 | 08:50 PM
4x4YOTA's Avatar
Long time since an update but I received my TG 4.7 tcase gears and got the truck moved to better suited work area at a friends house..
but out on top of that the truck isn't running right so it will need some more tuning
pics to follow
Old Jun 5, 2017 | 10:25 AM
Terrys87's Avatar
Truck looks to be in great condition. No rust to speak of. Great find.
Old Jun 5, 2017 | 05:52 PM
4x4YOTA's Avatar
thank you... other than the tailgate and rear window it is in great shape
