1984 pickup to 1995 4 runner rear end extended micro motor home build
Old Aug 17, 2016 | 09:21 PM
miketheband's Avatar
So here's what happened, I got a motor home with the recalled death dually's , and just couldn't live with the poor set up knowing the wheels could fly off and crush my lp tank blowing me to bits while only going 55 mph not the death I have in mind , I had a 4 runner I just bought for a part out and turns out there are quite a few similarities such as frame size axle comparability to the old drive shaft and with a little ' ton ' of modding I'll be on my way Rollin a 6 lug single tire rear with anti sway and air ride , to be continued .... Tomorrow
Attached Thumbnails 1984 pickup to 1995 4 runner rear end extended micro motor home build-image-4031252636.jpg   1984 pickup to 1995 4 runner rear end extended micro motor home build-image-3465367736.jpg   1984 pickup to 1995 4 runner rear end extended micro motor home build-image-1820823297.jpg
Old Aug 21, 2016 | 12:51 AM
SAyota's Avatar
That's on heck of a project!
Old Sep 1, 2016 | 09:42 AM
Terrys87's Avatar
Anything new going on this thread? I would like to see the conversion. Welcome to Yotatech.
Old Sep 1, 2016 | 11:08 AM
It's been kicking my ass but finally made some visible progress now that the welding and custom works done ,
went through 12 lbs of welding wire , but she's solid , posts are welded in and level for the rv floor , 2nd gas tank is in, I'll run a splitter to the generator and my primary tank and will be able to refuel while driving or fill the Jenny without even pulling over , so pretty excited about that ....
fabbed up e brake brackets and cables , new brake lines, cleaned out a lb of rust from the 85 pickup tank and painted it with some leakseal ,,,, it will be done soon with in next week or two
Attached Thumbnails 1984 pickup to 1995 4 runner rear end extended micro motor home build-image-1574377203.jpg   1984 pickup to 1995 4 runner rear end extended micro motor home build-image-446265228.jpg   1984 pickup to 1995 4 runner rear end extended micro motor home build-image-3984509301.jpg   1984 pickup to 1995 4 runner rear end extended micro motor home build-image-1785339463.jpg   1984 pickup to 1995 4 runner rear end extended micro motor home build-image-3086433929.jpg
SilentBounty
Mar 22, 2016 10:29 AM
BarefootGeologist
Feb 15, 2016 06:01 AM
Poppie51
Feb 10, 2016 08:42 PM
data
Jul 10, 2002 06:40 PM
Luke
Jun 12, 2002 10:58 PM
