yotantn's 1981 Pickup Build-Up Thread
Old Oct 17, 2013 | 03:17 PM
  #261
yotantn's Avatar
Bezel Transplant
Well, the stuff is just sorta propped in there and nothing hooked up, but that's a STRRRROOOONG resemblance to what she looked like when I drove her home off the lot October 12th, 1981.
Gotta get a bracket or something back behind the radio to screw it into. Me and my drunken friend sawed the right bracket out in 1982 to put a bigger radio/cassette in there.
Pretty cool, pretty cool indeed.
Lots to do to get that dash back like it was, but for right now...
I'm PreT durn happy.
Thanks to my new bud 1980lwb for contacting me about the bezel and radio.
You're now part of the 32 year history on my truck! lol.
I sorta laughed out loud myself when I remembered puttin my Aviators in that sunglass box.
Old Oct 17, 2013 | 03:25 PM
  #262
1980lwb's Avatar
Hope to see many more pics of the ol girl and hope to be able to find the other pieces your needing also!!!
Old Oct 17, 2013 | 04:17 PM
  #263
Abraham Contreras's Avatar
On the picture with the radio there on the bottom right corner there is a plastic cylinder that is connected with all the wiring to the radio and other stuff. Does anyone know what that piece is for? I was taking out a bunch of extra wires the previous owner had put in for an aftermarket stereo and this piece fell out but I have. I idea what it is for. I wish I still had my stock radio like this truck they ruined my bezel and all the compartments around the radio
Old Oct 17, 2013 | 05:00 PM
  #264
yotantn's Avatar
Are you talking about the fuse holder ? In the white cylinder? It twists apart and there is a fuse inside.
Old Oct 17, 2013 | 05:03 PM
  #265
Ya that's it so is it just a fuse for the radio?
Old Oct 17, 2013 | 05:08 PM
  #266
yotantn's Avatar
Yup.. Just twists apart buddy.
Old Oct 17, 2013 | 05:10 PM
  #267
I guess they didn't need it for the aftermarket radio they put in but thanks appreciate it
Old Nov 17, 2013 | 12:08 PM
  #268
yotantn's Avatar
So, just when you think you've got it all going ok...
New problem: She wants to OCCASIONALLY die while running down the road.
I had taken her back to the mechanic who is the best in the area, great guy..because on cold mornings she wouldn't crank without carb cleaner shot into the carb. Then crank and run fine.
He adjusted the carb some and I went to pick her up. She drove half way home and started dieing while driving. Took her back.
He fixed the choke plate (was in a bind) and adjusted the fuel mix.
Drove it home and did fine.
Next day, started perfect on first hit, drove perfectly to breakfast with a bud, then after leaving the restaurant, she started it AGAIN. I coasted over to a dollar store parking lot, called him and he came out..fed her carb cleaner while I fed her a little gas pedal on the inside and she overcame the need to die. Drove her 1/4 mile or so and she started it again. Repeated all of that..HE drove her to the shop and she drove fine. I'm accusing her of having an affair with him. He puts her in HIS bay by HIS own personal toolbox. lol
He's going to keep her and drive her around on errands and such to see if it'll repeat and he can figure this out.
New fuel in a newly reconditioned fuel tank.
Battery ok full charge.
Solenoid voltage ok, 13 amps.
Fuel shows in the lil window on the carb.
He says he doesn't think it's vaccuum lines because she would be dieing all of the time and not just occasionally. She has done it once with him.
I believe the Flux Capicator is messing up. I believe we need to get her to the town belltower at midnight on this stormy night and try to get her up to 133 MPH to get the Gigawatts she needs.
He doesn't think she'll go 133 MPH without quitting.
Any thoughts from you Yotaologists much appreciated!
Mark
Old Nov 17, 2013 | 12:29 PM
  #269
RobotMoose's Avatar
Sucks to hear you've got a mystery problem.
I had a similar issue develop and thought it might be the fuel filter, so I went to pull it just to find that a PO somewhere down the line had decided fuel filters are for jerks and had replaced it with a 2" stub of a BIC pen. It sounds to me like you have some kind of similar higher-load fuel delivery issue. You've mentioned the bowl is filling fine so it's good at idle, but under load at the right time, it starves and dies. I've seen this happen when the return line gets routed to the carb from the pump.
That's my two cents. I think it's great you've got a mechanic who's willing to live with it for a bit to get a solid diagnostic.
Old Nov 17, 2013 | 02:02 PM
  #270
gmack192's Avatar
I still say WEBER......LOL
Old Nov 17, 2013 | 03:58 PM
  #271
yotantn's Avatar
Thanks man, I'll send that to him!
Dood, I'm trying to keep from having to buy another, but if it comes down to it..yes..it'll be a Weber. Hate to have to pay for one (after having this one rebuilt and all) and then having to have it put back on..But, she's gotta run!
I can't believe trash could be in it still.
I'm banking on something electrical going TO the carb...heck..I dunno.
I work on hearts, not carbs.
Old Nov 17, 2013 | 07:30 PM
  #272
gmack192's Avatar
The factory carbs are good, but finicky.. The slightest piece of trash in the needle and seat will reek havoc...
Old Nov 17, 2013 | 08:05 PM
  #273
HighLux's Avatar
and the electric choke was designed by the same company as the Titanic.
I vote weber.
I love your truck so much. I cant wait for my lil blue trekker to be pretty like your truck.
Old Nov 23, 2013 | 04:07 PM
  #274
yotantn's Avatar
I vote weber.
Thanks for the compliment bud! It's an ongoing project for sure. He's been driving it for a week now around town. says it'll run like a top, and then sit at a redlight...idling fine. Then
DIE.
Like it's turned off.
He's taken the solenoid out and plugged that hole with a bolt and doing something with the idle solenoid. I don't know what EITHER of those things mean.
But he's ruling out anything to do with the carb.
Old Nov 23, 2013 | 04:10 PM
  #275
gmack192's Avatar
I wonder if the igniter is getting hot and cutting out?
I have 2 if that is it.
Old Nov 23, 2013 | 07:19 PM
  #276
yotantn's Avatar
I'll certainly mention it to him.
He did say that it seems like a pattern:
Crank good, drive awhile...let sit for 1 or two hours.
That's when the problem starts...after a good drive, then sitting off for a couple of hours.
And then....it might do fine for a few days?
Old Dec 11, 2013 | 09:29 PM
  #277
gmack192's Avatar
Did you fall off the face of the earth?? Hope all is well with you and yours.
Old Dec 12, 2013 | 02:53 AM
  #278
yotantn's Avatar
LOL, naw bud. Everything's fine. I did shut down my FB, too much drama and I really don't care that she's standing in line at Walmart. And soooo many people put mess on like 'pray for me, I've got a headache'...or 'pray for me, I woke up early'.
Just skip all that and say 'I'm needy...can somebody please give me some attention???'. My life is much cleaner without all that mess to have to filter through.
Anywho, actually today I'm going to pick the ole blue gal up from the shop. YOu know I had that random shutting down problem that he's really had issue with finding out why. He did remove and plug the solenoid and the idle solenoid. He says she has ran fine since then. He's been driving her around town a little. I certainly dunno.
But I'm gonna get her home today and drive her some. Guess we'll see. If she does run great, then I guess it was the solenoids???
So, good to hear from you. Hope your doing well.
Hope everyone here is having good holidays!
Mark and Dixie.
Old Dec 12, 2013 | 04:53 AM
  #279
kawazx636's Avatar
1 Like = 1 prayer for your truck
Comment = 10 prayers for your truck
Ignore = You're going to hell
LOL I had to do it!
Old Dec 12, 2013 | 05:01 AM
  #280
yotantn's Avatar
LOL I had to do it!
Hahahaha.. You seem to know what I'm talking about.!
I'm actually a praying man myself.
But your post here pretty much summed up that prayin FB scene.
That's pretty funny stuff dood.
