toyospearo's 1982 Pickup Build-Up Thread
Old Jul 19, 2010 | 07:45 PM
  #41
BigBluePile's Avatar
I wish I had the time!!!!
Old Jul 29, 2010 | 07:54 AM
  #42
2450paul's Avatar
Originally Posted by toyospearo
I picked up this 82 here on the north coast of CA. I looked and looked and this one kind of found me . The guy I got it from took really good care of it over the years but the rust got to be too much for him. He parked it, started it every now and again over the years and then he decided to let it go.
When I got it it was leaking oil from the valve cover and the oil pan. The output shaft seal was leaking as well. There are rust problems galore. I picked up new front leafs and a rebuild kit with bearings, new front rust free fenders and u bolt flip kits.
So far I have fixed all the gear oil and oil leaks, flushed the system and replaced most of the gaskets.
Below is the rig and a few mods... I plan on updating regularly so stay tuned.
The day I got it.
these came with it...
Finally got a decent welder!!
fixing rot..
more rot..
bondo to smooth it out (thanks Bindergirl!)
surf shot to keep from getting bored...
After fixing all the oil leaks I decided to rebuild the carb. I got a Napa kit and went to town!
back on, shiny as hell and running like a champ!!
New carpet goes in this week and much more to come!!
I've built some carbs in my day, but these Toys have the most compicated units I've ever worked with! Paul
Old Jul 29, 2010 | 03:26 PM
  #43
slacker's Avatar
some very nice rust repair right there .. ever want to move to Canada , i'm pretty sure I know a guy that might be able to put you to work restoring/building toyotas
keep up the great work !!
Old Aug 7, 2010 | 07:03 PM
  #44
toyospearo's Avatar
PAINTED!!!
I took it out for a quick spin after I got the bed back on to make sure things were tight. Wheels, tires and ADDICTED OFFROAD bumper are on the way. Here are a few quick photos..
Before...
after...
I also completely restored the inside. I will post up some of those and the new leafs tomorrow..
Old Aug 7, 2010 | 07:58 PM
  #45
TinMan's Avatar
Nice work man! Did you paint that outside? What was the process? Sealer, primer, base, clear? Thanks
Old Aug 7, 2010 | 07:59 PM
  #46
Looks great man!!
Old Aug 7, 2010 | 08:00 PM
  #47
toyospearo's Avatar
Yes I did paint it outside. It is a single stage Limco paint.
Tons of body work, epoxy primer, paint and a light buff out.
Old Aug 7, 2010 | 08:04 PM
  #48
TinMan's Avatar
Right on, I'll have to look the paint up. I am hoping to paint mine soon. We'll see, I tend to get ADD and jump around to much. Good work.
Old Aug 7, 2010 | 08:52 PM
  #49
2DoorRunner's Avatar
Dude your my hero. That is soo damn clean!
Old Aug 7, 2010 | 09:30 PM
  #50
UpTheYotaPunx's Avatar
beautious, what wheels/tires?
Old Aug 8, 2010 | 05:57 AM
  #51
toyospearo's Avatar
8" black rock crawler steelies and Pro Comp Xterrain 31 x 10.50 15's
can't wait till they get here
Old Aug 8, 2010 | 07:13 AM
  #52
Fink's Avatar
You never cease to amaze me toyo...great work.
The wheels, tires and Scotty's bumper are going to make that look like an entirely different truck...as if you haven't already accomplished that!
So glad I'm subscribed!
Fink
Old Aug 8, 2010 | 08:42 PM
  #53
those are gonna look BADA--!
Old Aug 9, 2010 | 05:38 AM
  #54
BackGateYota92's Avatar
wow man the truck is looking great!!! cant wait to see it with new tires and wheels and the bumper
Old Aug 10, 2010 | 05:26 PM
  #55
87-runner's Avatar
looks great! you really know what you're doing. wish mine looked like that lol
Old Aug 10, 2010 | 05:31 PM
  #56
gary_the_4runner's Avatar
how much for the floor mats? never seen anything like em
Old Aug 10, 2010 | 07:20 PM
  #57
toyospearo's Avatar
Got the front end totally done from hub to hub (thanks Wabbit ) as well as new OME leafs. Today I finished the rear end. U bolt flip kit, and add a leafs..
The front hanger stock pins WOULD NOT COME OUT
Sooo, I cut them out. I needed to fab a plate for both sides and drill new holes..
The front end r and r was a TOTAL PITA. It took me all of two days to get it done. In addition to a complete knuckle service kit with new bearings I also had to replace the rotors and calipers. Most of what could go wrong went wrong. I was very relived when it was done. I don't know if I have it in me to do another one.
Ready for new rims and tires!
Old Aug 10, 2010 | 08:44 PM
  #58
crazy, you actually got the pass/driver leaf springs. when i contacted ARB they said there was no real difference between the 2, both of mine are "A" springs. is there any visible difference side by side when they are lying on the ground?
Old Aug 10, 2010 | 08:54 PM
  #59
toyospearo's Avatar
Apparently there is a difference between the two. What that difference is I do not know. I do know that everyone I talked with regarding these leafs said you have to put A on the the drivers side.
I see absolutely no difference and I looked both of them over pretty well.
I am just glad they are in and that front end nightmare is over.
Old Aug 11, 2010 | 01:45 AM
  #60
TinMan's Avatar
Looks nice man. And it is a big job. But you will love the OME springs.
I did my front end the same way you did, just dropped it down with the break lines attached. Ended up stretching the break lines and causing them to narrow on the inside. Which made my brakes pulsate when applied. Which in turn made the rotors warp. So I did the V6 brake upgrade. New brake lines are $18.00 ea at advance. The cheapest I have seen for extended woven brake lines in on summit racing. Might be cheap insurance for your new rotors.
Just something to watch out for.
Later
