GMACK192's REbuild up of Old #7
Old Nov 20, 2012 | 06:02 AM
  #41
83Toyota88's Avatar
Any progress?
Old Nov 20, 2012 | 07:01 PM
  #42
gmack192's Avatar
I had a transmission that was in my sons old truck, blown 5th gear...I have a friend building a good transmisson out ot the 2..I blew the first 2 main gears out of mine. Hopefully it will be ready tomorrow..
Old Nov 20, 2012 | 10:08 PM
  #43
westjohns yota's Avatar
i miss my first gen, should have never sold it, wonder how well that setup for the snorkel would work on a 22re.... hmmmmmm
Old Nov 25, 2012 | 06:55 PM
  #44
gmack192's Avatar
I think it would be easier......Ya wouldn't have to make a box for the filter...
Old Nov 25, 2012 | 08:03 PM
  #45
yeah but i would have to deal with AFM, blah, crap electronics.....
Old Nov 26, 2012 | 04:02 PM
  #46
gmack192's Avatar
Negative....I moved the airbox on a Tracker I had..connected it with a ˟˟˟˟˟ sucker tube...... I believe the fancy store bought snorkles connect to the factory air box...
Old Dec 8, 2012 | 06:29 PM
  #47
gmack192's Avatar
It has been a long frustrating 2 months...A friend of mine worked on the trans for me, built one from the 2 junk ones I had...Well we thought it would work...as soon as I tightened down the cover everything would bind up....After several hours of screwing with it, I threw in the towel and bought a trans & Tcase out of an 89..So far everthing looks like it will work...I built a crossmember/skid plate so that handled moving the crossmember..I got the front shaft out of the 89, it fits....I will have to shorten the back shaft & my spare back shaft.. I have a long week at work..Hopefully I can finish everything up next weekend...I will try to get a picture of the crossmember/skid plate...
Old Dec 9, 2012 | 03:59 AM
  #48
dropzone's Avatar
Fossilized
Originally Posted by gmack192
I got the top finished this weekend....I think it came out pretty good, considering I had no clue as to what I was doing....
Drove it to work today, no flapping at all....I was worried about that.
How are holding down the leading edge?
Old Dec 9, 2012 | 03:03 PM
  #49
gmack192's Avatar
I cut the front rail of a Heep top channel in 3 pieces and screwed it down.. I unstiched the top and cut the plastic that was in it the same way & resewed it. The top came off a YJ Heep.
Old Feb 14, 2013 | 05:37 PM
  #50
gmack192's Avatar
Been a while since I've had any thing to post....The transmission fiasco was a pain in the A$$....
I ended up putting a transmission from an 89 in. I had to shorten the rear shafts ( I have a spare ) and I used the front shaft from the 89..
I made a skidplate / crossmember..
Installed..
Everything seems to be working pretty good....
Old Feb 14, 2013 | 05:41 PM
  #51
gmack192's Avatar
For Valentines day, I got myself a winch....
Front view.
Rear view.
I put it on a receiver mount so I can use it off my Tocoma & the tractor...
Old Feb 15, 2013 | 08:28 PM
  #52
83Toyota88's Avatar
Like the winch setup.
Old Feb 15, 2013 | 10:09 PM
  #53
gmack192's Avatar
Thanks.....Hopefully I can finish it Monday....And wheel with it Tuesday...
Old Mar 22, 2013 | 08:06 PM
  #54
gmack192's Avatar
Early B-day present...........Love craigslist, $950 for damn near new 12.50x36 Swampers.....
Compare to the 14x35 Gumbos.........
I sure hope these ride better....lol
Old Mar 23, 2013 | 07:55 PM
  #55
gmack192's Avatar
I need a way to idle the truck up while winching, so I did a little Yodarigging.....
Stole a high idle switch off my buddies Heep....I know, I know, but they are good for some things...I used a bracket from Lord knows where, but it worked perfect...
There was no where on the Weber ot the linkage for the switch to hit, so I welded a washer to an extra linkage I had.....That way if I fudged it up, I still had a good linkage.
The modded linkage on the left...
On the truck....Holds the idle @ 2100rpm...With the flip of a switch..
Opinons?
Old Mar 24, 2013 | 07:51 PM
  #56
gmack192's Avatar
SUMMER is coming (someday)....So its time to take the doors OFF...I had to figure out what to do with the door speakers, so I made some speaker boxes (cans).
The cans cut down...
The can mounted to the kick panel...
And the speaker installed...
Now if it will just get warm & quit raining so damn much.....
Old Apr 21, 2013 | 09:31 PM
  #57
gmack192's Avatar
Another Craigslist find......
In the truck.
I had to yodarig a hold down, made this from an old shifter linkage..
All done & ready for a test run..
OMF'N GAWD....Talk about waking up a 22R...Man what a difference...
Old Apr 21, 2013 | 09:36 PM
  #58
gmack192's Avatar
A couple of poser shots with the new 36's
Old Apr 22, 2013 | 06:38 PM
  #59
83Toyota88's Avatar
I just looked up that distributor and now I'm super jealous! Is it really as good as it supposed to be?
Old Apr 23, 2013 | 08:15 PM
  #60
gmack192's Avatar
Another Craigslist find...............
offenhauser dual port intake with 390cfm holley for toyota 22r - $175 (kodak)
offenhauser dual port intake with holley 390cfm four barrel carb. intake in great shape, carb. needs rebuilt
Picking it up tomorrow.....Pics to follow.
