83Toyota88's 1983 Pickup Build-Up Thread
Old Oct 16, 2012 | 01:49 PM
  #141
83Toyota88's Avatar
I painted all of the frame today from the gas tank to the transfer case support cross piece as well as the rear axle and front/rear driveshafts. What a PITA lol. Hopefully gonna finish the rest tomorrow. Tried to take a picture but didn't come out good.
Old Oct 16, 2012 | 02:15 PM
  #142
Logan81Pickup's Avatar
The bead itself looks consistent. However, its lacking penetration. Itll probably hold unless you smack something real hard.
I'm no expert btw.
Old Oct 16, 2012 | 02:22 PM
  #143
83Toyota88's Avatar
I'm no expert btw.
Thanks for your thoughts! How would I get better penetration? I had the voltage on high. The metal might have been to thick for the welder I think. I welded both side of all connections and gave it a good whack and it didn't move so It should be fine.
Old Oct 16, 2012 | 04:51 PM
  #144
Probably that. I usually go as high as I can on voltage without melting stuff.
It should be fine though seeing as its just for lights.
Old Oct 17, 2012 | 12:50 PM
  #145
83Toyota88's Avatar
Painted a lot more of the frame today. Ran out of paint and Walmart didn't have any more and the Autozone by my house doesn't keep it in stock anymore. Probably need one more can lol but oh well. I decided to start to work on this alternator bracket.
Got the grill, radiator, and fan shroud removed. All need to be cleaned and painted. Back side of the radiator had a good bit of mud on it. Antifreeze was super clean too.
Took a lot measurements of the engine and pulleys and this is what I got so far:
Side view of the motor:
I plant to use the three empty holes in the engine to hold one side of the mount and the bolt on the front to hold the other side. This is all to scale for the most part and the alt was just drawn on to show a reference of its mounts with the pulleys lined up. The alt should sit a lot lower than it is in diagrams.
Front view of the motor:
The three holes on the side I want to use are at an angle.
Sketch of the bracket:
Pics of the motor so you can see what I'm talking about:
So that's whats I'm looking at. If anyone has any input or feedback please let me know!
Old Oct 20, 2012 | 03:47 PM
  #146
83Toyota88's Avatar
Alright today was very productive. Got a bracket made for my alternator! Used 16 gauge metal. Its not sheet metal either. Welds are fugly but they hold. Here is the bracket not installed:
Goofy guy in the picture is my friend, he was bored and came and helped me:
Mount installed on engine:
Alternator installed:
Still got make the top piece to hold it in place. Im using the belt on the outside pulley rather than the middle pulley with nothing on it. If I used the middle one I would have to make some kind of tension bracket and with using the outside pulley I can use the stock one. What do yall think?
Old Oct 20, 2012 | 09:30 PM
  #147
ChefYota4x4's Avatar
It aint sexy.... but IF IT WORKS, WHO CARES? hahaha.
Great improv, man... And 'THUMBS UP' to buddies who come over and help... bored or not!
Old Oct 21, 2012 | 09:32 AM
  #148
83Toyota88's Avatar
Thanks. Im still gonna clean it and paint so it isnt rust colored lol. I wanted the alt to be higher up but oh well. At least its a lot easier to acess on this side.
Old Oct 23, 2012 | 03:45 PM
  #149
83Toyota88's Avatar
Painted my alt brackets today and put them on and the alt as well.
Yes its ghetto lookin but it works and didn't cost me but $10 for bolts and nuts!
Old Oct 23, 2012 | 04:08 PM
  #150
Lons81's Avatar
Guess I missed something, but how are you going to adjust the belt tension? I'm working on my right side mount, should have it done soon. Thanks for the ideas.
Old Oct 23, 2012 | 04:11 PM
  #151
83Toyota88's Avatar
Im using the outermost pulley/belt which has its own tensioner/idle pulley thingy on the top. This way I didn't have to make my own tensioner bracket.
Old Oct 23, 2012 | 10:27 PM
  #152
limited#279's Avatar
Looks good!
Old Oct 24, 2012 | 03:48 PM
  #153
83Toyota88's Avatar
I read the famous de-smogg a 22R thread on here and was looking at my truck when I got home and I dont see a lot of the parts lol. I see no smog pump or PAIR/Reed valve thingy. I do see the ERG valve though. The thread is on like a 79 truck and mine is an 83. Anyone know if there was a big change between then? Or maybe truck was mostly de-smogged already. My engine had been rebuilt before I got the truck and I'm wondering if they took a lot of that stuff off. I will be getting my 83 FSM in the mail soon, wondering what it will tell me about it.
Old Oct 27, 2012 | 02:28 PM
  #154
83Toyota88's Avatar
Got my FSM in the mail today!!!!! Its in great shape!
My labs all say hi to all other yota owners and their dogs. In other news I got a belt put on the new alt today. Ended up being a 54" belt. Bad part was I loosened the old alt tensioner to get the belt off and I put it back on and was tightning it and the bolt in the top broke off . So eneded up taking the whole old alt out and manged to get the rest of the bolt out and put a new one in it. Disconnected the wiring to the old alt as well. After all that I started the truck and reved it nice and high and everything looks good. Belt moves straight. Still gotta wire it up but thats what my FSM is for . Also put positive battery cable on. Stock one was hardly making connection and giving me starting issues.
Old Oct 27, 2012 | 03:35 PM
  #155
HighLux's Avatar
Not to be a jerk..but those extra long used brakelines concern me.
Please replace them.
Old Oct 27, 2012 | 09:23 PM
  #156
hhahahqa... love the dogs pic! (and the FSM )... They look like 2 on the right are smiling all big.... one of the left is not pleased! hehehe.
Looks good in there! Best wishes on the smog stuff's... I'm 12 years out since my 83... just can't remember. BUT, I'm watching, in case I get one
Old Oct 27, 2012 | 09:56 PM
  #157
westjohns yota's Avatar
god i miss the clean first gen i had......... should have never sold it
Old Oct 28, 2012 | 05:47 AM
  #158
83Toyota88's Avatar
Shame on you for selling it! Lol.
Old Oct 28, 2012 | 07:52 AM
  #159
school was more important at the time
Old Oct 28, 2012 | 10:53 AM
  #160
^^^^THIS, and "Should never have sold it " are contradictory... STOP IT! lol... You made a sacrifice that MANY MORE should probably make, but don't, because they're not seeing the big picture, ya know? I 'MISS' mine as well... Lil Blue was BEAUTIFUL, pretty much one of a kind... but NOT ONE OUNCE of regret... It helped pay for rent during first year of college!
NEVER REGRET, ... it's fruitless, COMPLETELY! .... Just reflect.... and reflecting, Josh, ... would you have done anything differently???? (and FORGET things that manifested AFTER you sold it that would have allowed you to keep it, ... again, POINTLESS, hehe).... SCHOOL IS more important..... NOW GET BACK TO SUNDAY STUDIES, YOUNG MAN!
