1983 toyota pickup 4x4
Old 02-02-2019, 04:44 PM
  #161
Abraham Contreras's Avatar
Slowly making progress with the intake manfold. Putting my new tool set to use and cleaned up all the threads and have new bolts.
The following users liked this post:
faber (11-27-2020)
Old 02-02-2019, 05:46 PM
  #162
NYHumpinUtah's Avatar
Your going to be glad you did this
Old 02-03-2019, 12:03 PM
  #163
84 yota dude's Avatar
Nice. I know I wish I had a welder too. Such a handy tool.
https://www.boltdepot.com/fastener-i...ade-chart.aspx
Black finish is just another type of finish.
Old 02-05-2019, 05:53 AM
  #164
Hey thanks for the clarification I appreciate it!!
I am glad that I went through with it and thanks again for always pushing me towards the right direction haha
Old 02-05-2019, 06:04 AM
  #165
I was looking into all my Torque specs since I will be putting everything back together soon and I noticed that the FSM calls for a sealer on the EGR valve??? I know that the intake manifold gasket I picked up from Toyota already has the gasket attached for the EGR valve so why need a sealer? I'm wondering if this is only necessary if you did not remove the intake manfold and only removed the EGR valve. But then again it says to apply a sealer on the upper right bolt which totally throws me off. Any idea guys?
Almost all threads I have found just talks about capping the egr valve for a de-smog but I cannot do that.
Here is what my intake Manifold gasket looks like, notice the egr valve gasket already attached.
Old 02-05-2019, 12:54 PM
  #166
Is this not for the bolt that goes into the coolant jacket? I believe that one of the bolt holes align with the coolant passage.
Old 02-05-2019, 01:52 PM
  #167
Mike, i'm not sure on what you are referring to. Are you talking about these two bolts closer to the middle of the intake?
Old 02-05-2019, 03:39 PM
  #168
Doesn't one of the bolts for the EGR go into the intake manifold and bolts to the block where there is a coolant passage? I think that's why they are saying to apply sealant to the threads of the bolt. Similar to some of the bolts that mount the timing chain cover to the block.
Old 02-06-2019, 07:42 PM
  #169
Mike, You may be right. Today i was cleaning up all the threads on the head and realized the top right bolt (arrow below) goes all the way through the head and into some passage like you mentioned. I'm assuming this is the bolt they are referring to and as you mentioned they suggest you put sealant on the threads of the bolt.
Would Permatex ultra copper be good to use?
Old 02-07-2019, 08:24 AM
  #170
Yep, that should work. Just on the threads of the bolt
Old 02-09-2019, 08:39 PM
  #171
Everything slowly getting put back together. I sure wish I took more pictures with all of these vacuum lines Then again it's good to just follow the diagrams and make sure everything is where it actually needs to be.
faber (11-27-2020)
Old 02-09-2019, 08:45 PM
  #172
Vacuum lines?? Whats that?
Oh, I forgot you live in the republic of California................
Old 02-11-2019, 04:09 AM
  #173
chowboy's Avatar
Sweet truck and resto Abraham..is that the S Bernie mtns I see?? Im up the pass in the valley of no apples. J Tree is the first place I’m going to when my 84 is done... just rebuilt the carb for $300 with Napa kit ...your more inclined than I am lol..the hammers just passed btw. Thanks for taking us along..it’s been a fun read
Old 02-11-2019, 05:50 AM
  #174
Hey Chowboy thanks I appreciate it!! The mountains with all the toyotas in it is the San Gabriel mtns but I'm from Chino so the San Bernardino mountains are close to me as well. I always enjoy taking a trip to Joshua Tree and hoping to go soon once this cold weather goes away lol I've been seeing everyone post about KOH and hope to go one year.
Old 02-20-2019, 06:38 AM
  #175
Alright everyone, the Intake and Carb is finally back on the truck
Took me long enough but hey it was a great learning experience and I also save lots of money doing it. After going back and forth with the timing and adjusting the carburetor I finally got it running smooth. I would like to lean it out a tad bit more and also turn the idle down a little bit more.
Here is a video of the truck running if you care to see Let me know what you guys think.
https://photos.app.goo.gl/f33J9MHm99QvkcMJA
Old 02-20-2019, 09:06 PM
  #176
Turn the camera sideways next time! Ha
Sounds pretty good to me!
Old 02-21-2019, 05:54 AM
  #177
haha ya my bad, I always forget to turn my phone sideways. Thanks for commenting!
Old 02-21-2019, 11:31 AM
  #178
old87yota's Avatar
The engine sounds pretty good!
You are getting close to a driving Truck again!
Old 02-21-2019, 01:42 PM
  #179
Punjab's Avatar
Nice work! That motor sounds spot on. It makes me thankful that although we have emissions and inspection here in Colorado, it's not nearly as tough as you California folks get.
Old 02-22-2019, 05:54 AM
  #180
Drove it to work today
Ya it sucks having to deal with all these emissions and paying for the smog test on top of our already expensive registration haha
Quick Reply: 1983 toyota pickup 4x4
