1981 toyota pickup DLX Project
Old Apr 9, 2014 | 05:29 PM
  #121
gillesdetrail's Avatar
Haha yeah we all learn and find inspiration from one another. A trick for the stripper is to brush only once, not like paint where you will go over many times and you can lay it down thick. Once it is layed down you cover it with a plastic bag so that the chemicals don't escape as quickly. After about ten minutes you pass your hand over the plastic to agitate the product because it only does one layer at a time, by agitating it the stripper also gets to the other layer. After another ten minutes you remove the plastic bag and if the paint doesn't come with the plastic, it is easy to remove with a scraper, hope this helps.
I just bought primer, paint, foam brushes and roller, 44$. So I still have 109$ to buy paint thinner, masking tape, sand paper, floor rubberized coating and acetone, not bad.
Old Apr 11, 2014 | 01:08 PM
  #122
So yesterday I wanted to try the paint remover, I started by slightly sanding the area with 60 grit (40 or 80 would be fine)
I prepared my stuff before starting, a cheap disposable paint brush, a plastic bag torn on both sides, and a little container with the paint stripper.
I then applied a thick coat. I should have started from the bottom up but oh well. Don't be affraid to put a thick layer but what is important is to brush only once at one place, don't go over many times like you would if you were painting.
After that I put my plastic bag on it, this is to keep the fumes from espacing the product and to keep the fumes down in my (ventilated) garage.
I then agitated the plastic bag with my hand to move the paint remover around so that it would also get to the bottom layer, usually the paint remover only removes one coat at a time.
This is what it looks like after not even 10 mins
I then took my scrapper (body filler spreader) and removed the paint and primer easily.
I read about another method, which was to apply the paint stripper, then after a minute or two you take a brush and brush where the stripper was applied.
I wanted to know which works best so I made a comparison on my roof, on the right side I used plastic bags, on the left side I used the brush method. As you can see, plastic bags work a little better.
After using two layers
I also finished installing the seat mounts, they fit really nice and are solid and safe. They are also reclinable and have little pockets behind them (just found out).
I welded a piece of angle stock all along the bottom side of the rockers for a little protection and strength.
My to-do list slowly getting shorter
Old Apr 11, 2014 | 01:13 PM
  #123
83 trail rig's Avatar
Good post looks good
Old Apr 18, 2014 | 11:31 AM
  #124
So I've been doing a lot of sanding and stripping and here is where I am. After I removed the old body filler I noticed that this cab is pretty beat up, the roof, rear and sides have a lot of dents, but I don't really mind, the biggest ones will get worked on and the other ones will be part of its 33 years of hard life.
I put the cab on for the last time before paint to make sure everything fits perfect including the doors, wich I hadn't bolted on since I started the body work, and they close perfectly, so the cab is straight and solid and it feels great sitting in it with the seats in their tracks!
More sanding and prepping,
I still have a couple hours of prep to do, then it's body filler time, then primer, body sealer and paint! Should be painted in two weeks or less if all goes well.
Old Apr 18, 2014 | 02:51 PM
  #125
kawazx636's Avatar
Looking good! I did a bunch of sand blasting to mine today - I really wish the PO hadn't put so damn much rubberized undercoating on it!! We're about at the same point though. You going to get new seals and window channel for your doors?? I have a good source if you are.
Just a FYI, You should spray the epoxy sealer before the urethane primer.
Old Apr 18, 2014 | 09:11 PM
  #126
Thanks dave! No I'm not taking apart the side windows or removing any weatherstrip or seal yet, these are the kinds of little things that will get taken care of in time once the truck runs and that everything mecanical is in perfect shape, so far it all looks good so I won't mess with it, I just really hope I don't have water infiltration but we'll see once it gets driven. About the sealer, I am not using epoxy or urethane primer (I think), I am just using the tremclad (rustoleum) primer, but I will lay that down before I use the body sealer.
Old Apr 19, 2014 | 02:43 PM
  #127
you have taken all this time and effort in this truck take those doors apart and do it right you'll thank yourself later
Old Apr 19, 2014 | 07:01 PM
  #128
I have removed the weatherstrip, inside panel and handle, I have removed the door handle and key barrel, and the hinges, but I won't remove anymore since I am afraid to rip the seal or to break something, right now the side widows seal well and work well so I won't touch them. The more I go along, the less time and money I want to spend on esthetics, that can be redone in time, plus if I come across another set of door I will probably buy them since mine are in pretty bad shape, there is lots of body filler, welded metal, a bit of rust around the frame too.
Old Apr 20, 2014 | 06:06 AM
  #129
Didn't know your doors where in bad shape your cab is looking so good I'm getting ready to cut my floorboards free and make new ones for my paint I'm going with an aircraft paint desert tan and black plus stripes like the 82 sr5's here's the thing I hate body work and wouldn't be able to paint to save my life but I'm going to pluss I'm dreading what the seals will cost plus wiring
On the up side I've been building engines trannys and axels for 20+ yrs so mechanically my truck will be a gem
I think we need to start some yota clubs
So we all get that needed help and hands
Old Apr 20, 2014 | 06:09 AM
  #130
Ps I bought my 83 two years ago put 148miles on it and then tore it apart I can't wait to finish it
Most likely I have another year to save and build
Old Apr 20, 2014 | 06:39 AM
  #131
Yeah bodywork takes patience and/or beer, but it looks as good as the time you put on it so it depends what your goal is in the end. I've seen your engine setup it looks means I'm looking forward to seeing your updates.
Old Apr 20, 2014 | 07:30 AM
  #132
Need to figure out why it won't let me download more pics
I have a lot in that engine way more than I wanted
Now in order to set the cage and rear bars I have to at least set up my cab and front rear shock towers to tie it all together
I could have driven that yota for years but I I have this problem leaving well enough alone
Old Apr 20, 2014 | 07:31 AM
  #133
I have pics of the engine with all the stuff that went into it just can't download at this time I need a computer
Old Apr 21, 2014 | 05:57 AM
  #134
kawazx636's Avatar
By body sealer, I assume you mean seam sealer then?
I would worry more about your paint pealing than your seals getting messed up if you try to paint around the seals, particularly the window channel guide seal and the outside reveal trim. I got all new seals for my truck, but the old ones came out in one piece and undamaged. They would still be useable, I just wanted to replace them with something new. If you decide to take out the old seals and damage them, you can have mine for whatever shipping costs.
Old May 4, 2014 | 06:05 PM
  #135
Thanks for the offer on the seals, we'll see how this all goes, and yes the correct term seems to be seam sealer.
Applied the body filler on most of the dents, the roof is all banged up on all sides, just like most of the cab too.
More and more sanding..
The front fenders were stripped to bare metal, the doors are in horrible shape, with about 1/8th inch of bondo everywhere, the bottom 4'' have a riverted sheet metal and there is a big patch of metal right in the middle, I have left all the holes from previous and curret mirror setup :p I will slowly be looking for new doors maybe for next year.
Finally it's primer time, tremclad with foam roller
Meanwhile I received many parts I've been wanting to order for a while
Drop drag link, adjustable proportioning valve, 90 degree npt fitting, adjustable fuel pressure regualor with gauge, transdapt weberto 20r adapter, adjustable fan switch and a residual valve. The 90 degree fitting are the wrong ones (my fault), the hole is too big, but they were the only 90 degree 1/8 npt fitting I could find, I'll see what I can do.
More priming on the floor, then I sprayed zinc primer on all the areas I was to apply the seam sealer so that it would infiltrate
My lousy seam sealer application, it is like welding, it takes lots of practice not to be messy. I put that thing on almost all of the welds, and all overlapping panels, and sealing everywhere water could infiltrate.
Underneath, same process, much nicer seam sealer aplicationg but I forgot to take pics!
Fenders, I hammered out a lot of dents quite nicely, most of them don't show and they look pretty good
I brought the hood home, it was also in bad shape but the good news is since this engine was so beat and neglected, many oil leaks formed keeping the hood rustproof, there is no rust anywhere, good thing I had the pressure washer, what a great tool
Since then I have cleaned and primered the hood, painted the underside too, I still have more work to do on the top though.
Engine bay and front end painted semi-gloss black (bad pic)
And today I applied the first two coats of rubberized coating. It didn't give the texture I wanted so I will be buying some gravel guard or something tomorrow.
So that's where I'm at, tomorrow I will finish the coating, this stuff lays down thick and with the rubberguard it should be good for soundproofing, I don't ever expect taking this stuff off though! I will also do more priming and sanding and thursday I should be ready for paint, I'm pretty anxious to see this thing painted and finished!
Old May 4, 2014 | 06:08 PM
  #136
HighLux's Avatar
Wow. Your getting it done. Man. Been waiting for an update. I didnt see where you had a color picked yet?
Oh...the maple hardwood floors above are sweet. One of my favorite floors.
Old May 4, 2014 | 06:12 PM
  #137
Thanks man yeah I've been putting about 15-18 hours a wheek into this thing, I'm really sick of body work and I want to start using my ratchet again! And yeah the floors are pretty nice my girlfriend had them done last year but the dog totally scrapped it and it's not getting better!
Old May 4, 2014 | 06:14 PM
  #138
Sweet
Old May 4, 2014 | 06:26 PM
  #139
HighLux's Avatar
I have 3 Shepherds, and wood floors. We try and keep their nails down....but Mauser won't let us do his...and we have to take him to the vet, put a muzzle on him, and its still like alligator wrestling. He will poop and pee in fear. We may see if we can give him a doggy Valium or something next time. Its an ordeal.
I cant wait till I can do some bodywork. I imagine Ill be a pro by the time the trekker is done. Still dont know if I will shoot the paint or not. Im watching to see how Kawasakis goes.
Old May 4, 2014 | 06:32 PM
  #140
As far as colour goes, I will mix white and brown paint to give a nice beige colour, the hood will be semi-gloss black, all trims will be black, and it will have yellow fog lights or driving lights. Kind of like this without the decals.
I think it gives it a nice retro look and it falls right in my tastes, plus when the truck came out the factory it was originally cream white/beige
