2010+ 4Runner 5th gen 4Runners
2004 Horn -- HELP!
Old Feb 11, 2015 | 08:10 AM
phoenix1055's Avatar
2004 Horn -- HELP!
I can't believe I cannot find the horn relay on my 2004 4Runner.
I hit the horn and it doesn't work. I replaced the fuse. It doesn't make a difference.
Anyone know where the relay is?? It's the only thing else that I can think of. Or am I missing something... (?)
Any help would be greatly appreciated... This is a mystery to me.
Old Feb 12, 2015 | 04:43 AM
Geez. Not one answer. Wow. No one knows anyone that ever had a horn issue or something similar to this kind of problem....
Old Jul 18, 2015 | 12:55 PM
rigtec's Avatar
Originally Posted by phoenix1055
"I can't believe I cannot find the horn relay on my 2004 4Runner..."
"...Any help would be greatly appreciated... This is a mystery to me."
Hi phoenix,
Mine is a '12 4Runner but I just happened to have an extra 'Relay/fuse box' from a '07 4Runner. EDIT: Sorry about that phoenix; when I started out, I understood that you were trying to locate the Horn Rly, but I pointed the fuse out instead. I just went through the Rly/Fuse Box that's on my work bench. I traced the (White w/GRN stripe) wire from the 10A horn circuit fuse to the wire bundle that leaves that box altogether; leading me to believe that the Horn rly may be located in the Driver-side fuse/junct box near the E-Brake. Now in my 4R that relay is in the main fuse/rly box under the hood, but yours may be different. I did a google search and a lot of late model Toyota's have their horn relay's under the steering wheel. Take a look at the cover on that box and it may be labeled! Cheers
Hope this helps, Rgds!
Ilovemountains
Sep 15, 2015 04:17 AM
xzen73x
Sep 14, 2015 03:00 AM
ErikZ1220
Sep 10, 2015 04:53 AM
Highlander Giant
Sep 8, 2015 06:46 PM
Tacoma1313
Sep 8, 2015 01:27 PM
