Vehicles - Parting Out Parting out a vehicle, post it here
FS[SouthCent]: Parting out 88 4Runner SR5
Old Sep 27, 2016 | 06:05 PM
  #41
Charchee's Avatar
Pretty neat. I do not have anything left of those lights. However, if you will send me a description or part number of the bulb, I'll help you find a socket for it. They are twist lock sockets aren't they? These things are actually pretty generic. You could use any kind of bulb you could think of and get the socket for that type of bulb. Why not LED bulbs in the signal section if you are using them in the forward part? Do you think you could post a good picture of the one socket that you do have? I really don't want to tear mine down to find out.
Old Sep 27, 2016 | 07:48 PM
  #42
dbbowen's Avatar
sure, I'll run out and take a photo. I'll send a photo of the housing it twists into as well. The reason why I don't want to use a led in there is because when I use them on my current USA model orange corner lights it's a very distinct dot of light. The halogens fill the yellow pretty evenly instead of just a small dot of light. You are right, they are twist lock sockets.
Here re is the back of the housings.
Old Sep 27, 2016 | 08:14 PM
  #43
Charchee's Avatar
That is going to be super easy. Just take one of them up to a local parts store and ask for a socket to fit it and a bulb like you want to fit the socket. That style is very common. Much better than installing a 27 year old twist lock socket into your new housings.
I don't like LEDs in a light like that either or really anywhere for that matter.
Old Sep 27, 2016 | 08:18 PM
  #44
dbbowen's Avatar
really?! It's that simple? Haha! I had no idea they just sold those sockets at local parts stores like autozone and stuff. That makes life way easier on me. I have LED tail lights and reverse lights because they use a reflector and work well, but the corner light looks kind of silly with the one bright dot. I'm hoping the led will be fine in the new corner light I ordered. Will kind of be somewhat unique too. I've never seen one around with those corner housings. Thanks for all of your time and help man, I really appreciate it.
Old Oct 12, 2016 | 09:49 AM
  #45
jzx81's Avatar
Does it have clean floor pans on the driverside? Would you be willing to cut one out?
Old Oct 12, 2016 | 03:29 PM
  #46
I8URSVT's Avatar
Any interior sunvisors?
Old Oct 22, 2016 | 06:08 AM
  #47
Charchee's Avatar
Originally Posted by Talongod
Do you still have the tailgate, if so how much do you want for it ?
I have a shell and most of the parts to build one but it has a few dings in it and I doubt you'd want to pay shipping on it to FL from here.
Old Feb 28, 2017 | 07:24 PM
  #48
Razorbackcruiser's Avatar
Looking for an SR5 dash cluster.
Thanks.
Old Mar 1, 2017 | 09:24 AM
  #49
vikingsven's Avatar
Looking for heater control assembly? Got one?
Old May 10, 2017 | 08:40 AM
  #50
881stgen's Avatar
I could really use the following:
Center console heater if it came with one.
Power antenna motor and antenna if it came with one
Old May 10, 2017 | 12:32 PM
  #51
Reed23's Avatar
you wouldnt happen to have torion bar parts would you? mainly I am looking for the top and bottom anchor arm adjusters (the torsion bar adjustment bolt sits in these) for both sides and possibly the torsion bar adjuster bolts/nuts if they are in decent shape. mine are completely seized together and I havent been able to find the anchors that arent on back order.
Old May 13, 2017 | 05:46 PM
  #52
Trucker4life's Avatar
Im looking for the A/C evaporator and housing with wiring.
jleathers
Jul 12, 2023 05:46 AM
Dexter350k
May 19, 2021 10:31 AM
shisha1999
Feb 4, 2016 12:17 PM
bigbog
Jan 30, 2016 03:57 AM
Nate C
7
Jun 28, 2002 10:09 PM
