Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
Help identifying knock noise coming from blower motor in 2007 Toyota Matrix
Old Nov 4, 2019 | 07:58 AM
CanRunner's Avatar
Hi, I’ve been experiencing a knock noise coming from my blower motor or something in contact with that assembly. It is random and fairly infrequent, occurring every minute or two. There is nothing loose in the blower motor and I can’t track this down. The next thing I will try is putting a volt meter on the fan power and see if there is a voltage drop or spike that is causing this. It only happens when on high, can a failing resistor on the motor control do something like this?
Any thoughts?
Thanks
Old Nov 6, 2019 | 11:48 AM
old87yota's Avatar
I am not sure what is causing your problem, but I am certain that a blower motor resistor would not cause a knocking noise.
Are you 100% sure there is no debris or loose parts near the fan?
Is the cabin air filter installed?
DupermanDave
Jan 13, 2016 09:31 AM
91muddog
Sep 15, 2011 09:46 PM
haymaker75
May 22, 2011 02:26 PM
chorst294
Nov 19, 2008 05:18 AM
all_rice
Jul 18, 2007 10:35 PM
