Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
Complete baffle
Old Jan 18, 2020 | 02:47 PM
rollcenter's Avatar
Complete baffle
Story
1979 DODGE MB 400 <its a RV
PROBLEM As someone turns the Wheel you can see the upper control arm and ball joint CHANGE CASTER with a loud pop
Replaced ALL 4 CONTROL ARMS BALL JOINTS BUSHINGS STRUT ROD BUSHINGS BEARINGS RACES ROTORS CALIPERS the Front end is ALL BRAND NEW other then TIERODS they are fine!!!!!
The only thing I have not changed is the spindle it goes down the road pretty good then in the ruts it starts to hunt I think that is do to TOE IN cuz I haven't got it Aligned yet !
it changes caster so much the the rim rubs on the back side of the upper control arm !!!!!!!
Me thins the SPINDLE is jacked upor the ball joint hole is worked out of spec?
I am at a loss any IDEAS
aowRS
Sep 13, 2017 08:22 AM
TheOriginal
Nov 7, 2012 11:57 AM
BajaRunner
12
Jan 5, 2010 07:20 AM
BajaRunner
Dec 12, 2004 04:02 PM
bikeguy18974
18
Jun 11, 2004 07:05 AM
