wtb rear third member 4.10 8.4"
Old Jan 24, 2008 | 09:54 AM
rosscopeeko's Avatar
Hey guys, i need a rear 3rd member for my 97 tacoma, non elocker type. Has to be 4.10 ratio and in good working order. I would need it in WA state, or need to have it shipped there. If you have a elocker axle complete with the same ratio let me know what you want for that. I bought a front and now need a rear to match the new ratio. Thanks
Old Jan 24, 2008 | 10:31 AM
hross14's Avatar
are you saying that your is a 8.4" rear? I dont think they came with the cross braced Big 8 incher.
I have a 8" V-6 third with a True Track LSD--was in my 1997 4Runner. I was only able to 3k on it before i was hit and rolled. It was set up by Inchworm gear with solid pinion spacer. worked great
Email or call if interested 512-917-7097 or hross14@hotmail.com
Old Jan 24, 2008 | 02:51 PM
I'm no pro but from what i understand the elocker rear is an 8" and the non is a 8.4" in tacomas, or that's how they call it on another tacoma forum. I really don't know if the 4runner 3rd would fit, i'd have to look into that.
Old Jan 25, 2008 | 08:03 AM
hross14's Avatar
i will look at my buds tacoma here at work--and see what rear he has.....FYI--it is actually 8" also but has added bracing over the bearing caps....Do you have it out?
Old Jan 25, 2008 | 08:49 AM
No, it's my dd and currently has 3.58's in it which are crap. I know the earlier Tundra's and Tacoma 3rd's are interchangeable, not sure on the 4runner. I seem to think they are the 8" that is in the v6 toyota pickups, but i'm not 100%. Let me know what your buddies diff looks like. My truck is a 97 2.7.
Old Jan 25, 2008 | 09:16 AM
hross14's Avatar
The rear axles on all the earlier trucks up to third gen have interchangle 3rds. Even a 4 banger rear third can be put into a V-6 rear axle and vise a versa. I will do a little research and see what kind of axle you have.
Old Jan 25, 2008 | 09:25 AM
hross14's Avatar
The link below will tell you how to determine which third you have without having to take it out. My Friend is not at work today so i couldnt look at his truck--but basically, if the nuts on the third are 12MM--it is the V6/Turbo Diff (Same as mine). If the bolts are 14MM--then it is the large 8" trussed diff.
Hopes this helps
http://home.4x4wire.com/erik/diffs/#v6/turbo
Old Jan 29, 2008 | 06:44 PM
Still need a tacoma non elocker third in 4.10, or tundra third 4.10. Anyone? Rear third needed.
Old Feb 4, 2008 | 10:23 AM
MSR's Avatar
MSR
that ratio in an 8.4 is very expensive even used they go for $500 the ring and pinion is $700 new
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
