Solid FJ40 in Eastern Pennsylvania
Old Dec 6, 2006 | 11:13 AM
krawlin40's Avatar
Cool Solid FJ40 in Eastern Pennsylvania
This is a great deal it is a great price. Price is firm listen to what you get. Don’t let it slip by. I hate to do it but I am thinning the heard and do not have the time to use it anymore. I am posting it to fellow Toyota people only. One catch, if you ever sell it, contact me first! When you see what you get for the price you will be happy and eating jeeps in that price range for breakfast!
Here is the list:
This rig has been used not abused, paint is faded, minor scratches and dents, I have built a dependable rig for easy to intermediate trails great articulation geared good for tire size(no drivetrain/gear mods) that is still a road worthy solid vehicle for many years to come. I have driven it to Paragon(1 ½ hours) and wheeled it at Paragon about 8 times and it has always been a blast and always got me home safely! ROCK SOLID Hate to see it go. Price is firm don’t miss it $4500 drives it away crawlin40@hotmail.com, 610-683-7955 before 9pm EST Matt TLCA#12322
1975 FJ40 First $4500 takes this rig don’t miss it
BAD NEWS FIRST:
Bad news needs a new Muffler or repair (just Muffler all pipes are newas well as header, and muffler is less than a year old new one can be bolted right in) and wiper motor rebuild/replace, brushes are bad if you have an alternator rebuild shop near they can do it, have already installed a new Toyota wiper switch $65
GOOD NEWS:
PA inspection 3/07 smog exempt under 5k a year
desmogged original 2-f, stock gears, xfer case, 4 spd tranny
115k
Red w/red herculined interior
All work mentioned has been done in the past 4 years (body tub work is the exception) by me or Gary Schmauch, a major contributor to the TLCA on the east coast.
Mini truck PS/JTO bracket, Saginaw pump (allows use of a thick Toyota style drive belt)
Land Cruiser front disc brakes with all new seals and bearings, New MC
Jim Chenoweth Carb rebuild (awesome)
JTO headers and new exhaust
Front Passenger shoulder belts (’75 came only with laps)
New clutch, pressure plate, TO bearing, soft line
New TOYOTA FACTORY STEEL GAS TANK, all soft fuel lines
Kyosan Factory fuel pump
Poly Bushings
HFS 1 ½” shackles front and rear
Add-a-leaves in the front stock springs, 4” ranchos in the rear
5 33x 9.5 Mud Terrains with less than 5k on them
Extended rear soft brake line
4 new Rancho Shocks, new steering stabilizer
110 amp High output alternator
Mean Green Starter
Pioneer CD Player, Deka Intimidator Battery (Gel Cell, Optima Type)
New radiator (JTO) belts, hoses, thermostat
Cool Cruiser winch bumper on the front with Warn 8274 with 5/16 tow truck cable
Custom rear bumper with swing out tire carrier and box hitch set up, 4 prong trailer electrics, and protected rear tail lights built in
New front fenders
Cowl is rust free
Windshield is new and windshield frame is almost rust fre dime) size spot
Tub has been repaired with smooth plate steel placed over the wheels and rear tub area, all is solid with no visible seams
Rear ¼ ‘s are butchered a little bit on the corners due to a previous bolt on Confer Tire Carrier and some minor cutting to fit the ambie doors on after the
re-skin
Front doors have minor rust, no rust through
Rear ambie doors are 100% Rust Free
Hard top has some minor rust
Frame is rust free, pressure washed Waxoyled in the frame rails and epoxy painted surface 3 years ago
+MORE MORE MORE
Dodge Raider forward facing seat as well as jump seats, ammo cans for storage can be bolted to wheel wells with forward facing seat installed allows tons of storage +fitting 4 passengers, Fully assembled front roll cage, not installed, Trail spares=birfs with long and short half shafts, front and rear drive shafts, bikini top, fender flares etc. I will also include a Toyota early model transfer case for lower gearing, If you want to put 35”s on it grab a import 4spd from Cruiserparts.net and get a good low gear ratio with Toyota parts gear ratio fo 48 to 1 believe
Have All receipts $4000+
Old Dec 6, 2006 | 11:30 AM
da_bigg_wigg's Avatar
Old Dec 8, 2006 | 06:03 AM
ken.vs.ryu's Avatar
Any pictures?
Old Dec 11, 2006 | 07:47 PM
truvaine's Avatar
hey, i posted on your thread on Ih8mud.com too.
any pics?
barbourk@etown.edu
ashamsuddin
17
Jul 22, 2024 03:59 AM
TheBFA
Feb 15, 2020 06:55 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
ToyotaMD
Sep 22, 2015 06:28 AM
