potential ScanGauge II group buy
#41
I Posted it on www.tundrasolutions.com and at least a couple people have ordered from there.
#42
#44
#45
BTW nobody posted on there that they bought it, but they PM'd me
EDIT: I guess you already found it, I need to type faster
#46
#47
couple more purchases
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
10. NorcalPR (TTORA)
11. jktt
12.
13.
14.
15.
16.
17.
18.
19.
20.
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12.
13.
14.
15.
16.
17.
18.
19.
20.
#48
these wont work on 2nd gens will they... OBDII didnt come out till 97 correct?
#49
All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped. In general, this means all 1996 model year cars and light trucks are compliant, even if built in late 1995.
Two factors will show if your vehicle is definitely OBD II equipped:
1) There will be an OBD II connector as shown below, and
2) There will be a note on a sticker or nameplate under the hood: "OBD II compliant".
#50
ya i found that after posting... thanks tho
#51
Aren't there different "flavors" of the OBD II that may prevent Tofer from being able to use it? I thought that this was touched on in another thread, but I can't seem to find it. Or am I way off in left field?
I'm just trying to make sure that you don't get the thing and find out your connector is different
#52
#53
Flavor wise, I hit on that at the top of this thread. OBD II is an electrical/ connector/data spec, there are various protocols that are used to communicate on the hardware to get the data from the ECU to the outside world.
#56
just ordered
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12.Teotwaki
13.
14.
15.
16.
17.
18.
19.
20.
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12.Teotwaki
13.
14.
15.
16.
17.
18.
19.
20.
#57
list updated:
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12. JoeRobbins
13. Teotwaki
14.
15.
16.
17.
18.
19.
20.
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12. JoeRobbins
13. Teotwaki
14.
15.
16.
17.
18.
19.
20.
#58
#59
1. humanoid
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12. JoeRobbins
13. Teotwaki
14. Wimpwgn
15.
16.
17.
18.
19.
20.
2. AH64ID x2
3. dibble9012
4. skipo
5. Rembrant
6. Tanto
7. Ironmike4x4
8. mrjohnnycakes
9. Dremel
11. jktt
12. JoeRobbins
13. Teotwaki
14. Wimpwgn
15.
16.
17.
18.
19.
20.
