Parting FJ60 in northeastern PA good 2F engine
Old Sep 5, 2006 | 04:37 AM
Shmukster's Avatar
Got in another FJ60 this weekend. Wheelwell rust and rusty rear shock mount crossmember the only problems I can see. This truck runs and drives very well. IN any event I'm gonna part it out, the transfer case and power steering box are spoken for but other than that everything else is available. This is an unmolsetd truck, bone stock down to the original radio (plays quite well as a matter of fact) and spare tire. Red truck with gray interior.
Engine runs great, sounds good doesn't smoke at all that I can see and starts fine even without the choke. Will do a compression check for a serious buyer. engine will be sold complete with alternator, water pump and clutch fan unit, bellhousing and clutch assembly, electronic distributor (still has the rubber boot buttoned around it), complete intake manifold, carb and air cleaner, exhaust manifold. I'll also include the smog pump and all the smog equipment, remember this is an unmolested truck and all the smog gear as far as I can tell is still in place and working. Price $650 you can come hear it run.
This engine has the bolt holes for mounting the factory power steering pump and bracket of course. I can sell the PS pump and bracket for $75 or leave it on the engineprice of the engine with PS setup $700.
Other items:
4 speed tranny works fine $50 Gear drive starter $45
Third members 3.70 ratio $50 each Either driveshaft $20
Steering knuckle either side these are the big stud knuckles $50 each
Birfields with outer axle $50 each Inner axles either long or short $20 each
Complete exhaust system- brand new tailpipe and muffler cat looks good $75 pickup only Aisin hubs the good ones nice shape $85 the pair
Nice gray dash pad $75 buyer needs to suggest how to ship
Front end- nice fenders, hood and grille- some rust at bottoms of fenders but this is a pretty decent front end- $175 the works Windshield $40
Bumpers- no rust through- some discoloration- rubber ends intact $55 each
Original AM/FM radio plays well good knobs!!!! $75
Doors- no rust through that I can see. There are some dents but these are better than most FJ60 doors I see. $45 each
Tailgate (lower) no rust thgrough $60 Nice gray steering wheel $20
Upper hatch no rust through but not perfect $50
Set of Gabriel premium gas shocks less than 500 miles on them $60
AC compressor- this truck has cold AC $45 condenser $20 pickup only
Radiator truck doesn't overheat no coolant leaks $25 pickup only
Rear tail light assemblies original Toyota not the faded aftermarket $35 each
Stock chrome wheels with tires with good tread $75 the set of four
Ask for anything you don't see. Parts located northeast PA near Paragon and Rausch Creek offorad parks. I would prefer to not ship the bigger parts but will if necessary. I can shrink wrap the engine to a pallet and have it ready for pickup at the receiving dock where I work if buyer makles payment and pickup arrangements. Hit me offlist shmukter@pa.metrocast.net or call 570-668-2489 before 8PM eastern time. Thanks, Shmukster
Old Sep 22, 2006 | 12:07 PM
ToyotaGuru's Avatar
Got Front Rotors is GC?
Old Nov 9, 2006 | 09:16 AM
JGM's Avatar
JGM
Interested in the knuckles - what year FJ60?
DeathCougar
Apr 1, 2018 11:29 PM
4x4-runner
Apr 18, 2017 09:08 PM
alimant100
Jan 20, 2016 05:58 PM
digdug40
Aug 28, 2015 02:24 PM
lectric80
Aug 11, 2015 12:02 AM
