parting a couple of 3.0's & 91 runner
Old Feb 6, 2008 | 07:11 AM
89sammy's Avatar
what year? i found out the hard way that 88 has different injectors than all the other 3.0's. they have 14 ohm and then they changed them to 2 ohm. i have the 14 ohm injectors from my 88 that are good, i could'nt use them on my 91 motor.
Old Feb 6, 2008 | 08:47 AM
breesej's Avatar
88 or 89, I have a 1st gen.
Thanks
Old Feb 6, 2008 | 09:12 AM
89sammy's Avatar
Thanks
so its an 88, or 89 believe me when i say that they are diffrent. this is something that 3 trained toyota techs did not even know.
Old Feb 6, 2008 | 09:15 AM
breesej's Avatar
I don't know exactly. I'll bet that if I said 88, I actually have an 89 or vice-versa. I'll call the mechanic and see if he can tell me the ohm rating on the injectors.
Stay tuned...
Old Feb 6, 2008 | 09:40 AM
  #25
89sammy's Avatar
Stay tuned...
ok they also have different plugs so the wrong one wont plug into your harness. if you can take a close up shot of your injector from the top view then i can tell which one you need.
Old Feb 6, 2008 | 11:57 AM
  #26
89sammy's Avatar
Originally Posted by DH6twinotter
Here are the enterior parts I'm looking for (blue inteiror):
all 4 headrests
dash pad
trim piece at buttom part of door sill on the driver's side rear door (snaps or screws into the door sill and overlaps carpet)
If you were closer, I'd nab the front seats too, but shipping for those would probably be $$.
Thanks,
Daniel
pm sent
Old Feb 7, 2008 | 06:20 AM
  #27
breesej's Avatar
Denso 23250-65010 injectors.
I need at least one, maybe 3. I had mine cleaned by witchhunter performance and they were damaged in return shipping.
Do you have the correct injectors? If so, are you willing to sell less than 6?
Old Feb 7, 2008 | 06:25 AM
  #28
89sammy's Avatar
i will go check today, but 3 is fine. is $35 shipped reasonable?
Old Feb 7, 2008 | 07:04 AM
  #29
breesej's Avatar
$35 is fine with me.
Old Feb 11, 2008 | 09:54 AM
  #30
breesej's Avatar
Any update on the availablilty of the injectors?
Denso 23250-65010
Old Feb 13, 2008 | 06:34 AM
  #31
89sammy's Avatar
Denso 23250-65010
sorry for the delay, i got stuck in southern IL in a 4inch ice storm for 2 days, anyway i found the injectors but the numbers are 23250-65020 and they are out of my 91 and they are the same in all years but 88. let me know.
Old Feb 19, 2008 | 08:39 PM
  #32
shonkong's Avatar
I'll take the 3.0 fan and shroud radiator too if the price is right p.m. me
Old Feb 20, 2008 | 05:38 AM
  #33
89sammy's Avatar
i have the fan but no shroud, how is $35 shipped?
Old Feb 21, 2008 | 10:55 AM
  #34
morrison's Avatar
Do you have the crossmember that supports the transfercase?
Jim
Old Feb 21, 2008 | 01:34 PM
  #35
89sammy's Avatar
Jim
yes but i wont be stripping anything off until it warms up here, probably about 1 month, to muc ice to deal with.
Old Feb 21, 2008 | 01:45 PM
  #36
nolimit's Avatar
Need engine compartment wiring harness for 1988 3.0, If you have one whats
the price & shippnig to area code 36375. Thanks
Old Feb 21, 2008 | 02:07 PM
  #37
24Runna's Avatar
Is the 3.0 water pump working?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Alaskan91
Sep 21, 2015 04:39 AM
ZONAYODA
Jun 30, 2015 05:36 PM
yamaha73
Jun 18, 2015 06:19 PM
