parting a couple of 3.0's & 91 runner
what year? i found out the hard way that 88 has different injectors than all the other 3.0's. they have 14 ohm and then they changed them to 2 ohm. i have the 14 ohm injectors from my 88 that are good, i could'nt use them on my 91 motor.
I don't know exactly. I'll bet that if I said 88, I actually have an 89 or vice-versa. I'll call the mechanic and see if he can tell me the ohm rating on the injectors.
Stay tuned...
#25
ok they also have different plugs so the wrong one wont plug into your harness. if you can take a close up shot of your injector from the top view then i can tell which one you need.
#26
Here are the enterior parts I'm looking for (blue inteiror):
all 4 headrests
dash pad
trim piece at buttom part of door sill on the driver's side rear door (snaps or screws into the door sill and overlaps carpet)
If you were closer, I'd nab the front seats too, but shipping for those would probably be $$.
Thanks,
Daniel
all 4 headrests
dash pad
Thanks,
Daniel
pm sent
#27
I need at least one, maybe 3. I had mine cleaned by witchhunter performance and they were damaged in return shipping.
Do you have the correct injectors? If so, are you willing to sell less than 6?
#28
i will go check today, but 3 is fine. is $35 shipped reasonable?
#31
sorry for the delay, i got stuck in southern IL in a 4inch ice storm for 2 days, anyway i found the injectors but the numbers are 23250-65020 and they are out of my 91 and they are the same in all years but 88. let me know.
#33
#35
#36
Need engine compartment wiring harness for 1988 3.0, If you have one whats
the price & shippnig to area code 36375. Thanks
#37
Is the 3.0 water pump working?
