FS: R154 bellhousing
I got a R154 bellhousing for sale. This is just for the bellhousing. I only accept U.S. postal money orders or a personal check. Sorry I do not have Paypal. $70+shipping Located in Binghamton, NY.
James
James
Which R154 bellhousing is this? The R154 was bolted up to several motors.
M series bellhousing I assume?
The R154 also came on the 1JZ (and will bolt up to a 2JZ too). Input shaft length is the same. Flywheel, and clutch assembly are identical to that of a 7M, except the JZ crankshaft bolt pattern is an 8 bolt rather than the M series offset 6 bolt.
You don't find those a lot in North America, but it's worth mentioning
So you asked which motor this came off of but it is all the same whether it was a M series motor or a JZ. You do not find many of these here in North America? Their is tons of these transmissions. I see 87-92 Turbo Supra's for sale on Ebay and Craigslist all th time.
To answer your original queston, I do not know exactly what this came off of all I know it is a R series bellhousing for the Supra's. I assume it came of a 7MGTE motor.
James
James
Here is some more info: http://www.supraforums.com/forum/sho...10#post6179410
http://www.4cefed.com/w58vsr154/w58vsr154.html
James
James
No, I meant you don't see manyof the JZ R series bellhousings a lot over here.
And no, it's not the same. The engine bolt pattern is completely different. I would say 99% that yours is a M series though.
So to answer anyone's question, this IS a R154 bellhousing for the 7MGTE engine.
James
1997, 1jz, 4runner, bell, bellhousing, case, craigslist, fs, housing, moter, r154, sale, series, transfer, transfercase
