91 22re 2wd toyota being parted out
Old Aug 6, 2006 | 11:32 AM
desert whomper's Avatar
hey all, my truck is being stripped down to get a cage and a 3.4 for baja next year. Pretty much everything in the truck has gotta go. I am only keeping things like the rear axel, frame, cab and spindles/brakes. Currently the motor has around 35,000 miles on it after a rebuild and new parts. Previous owner said the block was new... i have had the head off and the pistons and cylinder has no markers to identify overboaring so they seem to be new. THe head has around 5,000 miles on it. It is a new casting with new valve seals springs and a re-ground cam. make an offer on anything and if something comes to mind ill see if i can take it off and ship it too you. Alot of it is sitting in the garage and jsut needs to be cleaned up. PM me or email me nkariger@gmail.com
Old Aug 6, 2006 | 03:29 PM
Robert m's Avatar
you got PM
Old Aug 7, 2006 | 12:47 PM
4runnerD's Avatar
Where are you located?
Old Aug 10, 2006 | 07:24 AM
Yotarebuilder's Avatar
a/c
Do you have an a/c system on the vehicle??? I would like to buy all the a/c system parts from you... condenser wire harness for system the ac control inside with the ac button in it a/c pump brackets hoses the box under the pass side with the coil that the air flows through ect... I want to put the system in my 85 4 runner sr5 22re....I just rebuilt the engine and its an everyday driver and man is it hottt and i need a/c bad... Im pretty shure it will work.. Do you know if i can do this any info?? Thanks Jon...
Old Aug 13, 2006 | 02:31 PM
i am located in lancaster, palmdale area... its about 90 mile snorth of LA. I will consider drving to meet if its possible. I have plans for the A/C so i will need all of it.
Old Aug 14, 2006 | 08:16 AM
BearsRunner's Avatar
Hey Whomper, How much for the tranny, and is it a 5spd?
Old Aug 17, 2006 | 04:47 PM
Do you still have the tranny?
Old Sep 15, 2006 | 12:51 PM
Adam F's Avatar
How about the rear bumper BRACKETS?
Old Sep 25, 2006 | 03:53 PM
starlord's Avatar
pm'ed
Yont283
Sep 23, 2022 08:06 PM
bigblue82
10
Jul 6, 2015 08:27 AM
DanStew
Jun 29, 2015 10:46 AM
paxanders
Jun 21, 2015 06:29 AM
Snort
Jun 20, 2015 11:08 AM
