85 yota buggy project in Va
Old May 4, 2008 | 07:58 PM
88rnr86up's Avatar
1985 4rnr frame
was built by kajo4x4toy
http://www.pirate4x4.com/forum/showthread.php?t=316243
pic's below with detail of what comes with it now
this is how I bought it
parts I installed till today
front axle 5.29's,locker,30 longs,studded new v-6 brakes,stub cap no hubs armor 1.5" spacer's
rear axle ifs 5.29's spool all new brakes studded housing
22r lc engineering motor weber/offy set up serial #10071
83' tranny and t case
stock column and harness(wired all lights included)
ifs steering installed shaft made to column
all parts included for obo (need bolts for comp)
parts need to finish
both d-shafts,brake lines and master(1 ton chevy),high steer,exhaust(has header weld up egr holes),fuel cell,elect fuel pump,air shocks rear,shock for front
$2200 as is or parting out soon
(will be keeping both axles if parted out)
Old May 4, 2008 | 07:59 PM
88rnr86up's Avatar
all new bearing/seals in both axles
extra parts to go also
Old May 6, 2008 | 03:22 PM
88rnr86up's Avatar
[IMG[IMG]http://i37.photobucket.com/albums/e99/muddy4rnr/SANY1563.jpg
[/IMG]]http://i37.photobucket.com/albums/e99/muddy4rnr/SANY1564.jpg[/IMG]
few pic from today
Old May 6, 2008 | 03:24 PM
88rnr86up's Avatar
all pic's I have of it now
Old May 7, 2008 | 12:50 PM
88rnr86up's Avatar
comes with both complete axles,chassis is a roller motor runs good miles around 30k bought from a friend, elect choke issue when cold nothing else
changed in a 83 trany/t case wont fit between center tube work it is set up for dual cases( cut and move or add dual's) both axles have o mile front is full rebuild 30 longs,complete v-6 brakes with vented rotors 1,5 spacers 5.29's with a locker,rear is ifs with 5.29's spool (need fld added)both housing are studded as well as the front hub stud kit and stub caps no front hubs front spring are a mix of rears and 5" soft ride skyjackers w/ boomerang shackles, rear 4 link is still set up for 14" air shocks tire are 36x14.5x15 mickey baja's on 15x10( dont know back space)
gas/brake/clutch/e brake assemblies are there and work need to bleed clutch,currently starter,clutch cyl are not hooked up as I just put in trans,have radiator,motor has all assecories hooked up needs the 4 bolts to ac comp obo parts are in a box
air tank is still mounted it back has 2 ground cables but only a 10 gauge pos cable for starter
wired in all factory lights and have harness(89v-6 at 4rnr) to run headlights/offroad lights temp place carb fuel tank in back to test run motor and check wiring
needs rear air shocks,1 ton chevy master cyl, few brake lines,mount ps resivoir, bolt steering column to plate,high steer kit,seats
copy from an email I sent about details
Old May 7, 2008 | 02:19 PM
cgeorge's Avatar
looks like a nice project.. my neighbors would KILL me if I had that in my driveway.
maybe one day I'll live somewhere that I can have something like this.
Old May 10, 2008 | 06:32 PM
88rnr86up's Avatar
buy it I wont tell em
update will sell chassis for $500 with:
4 link with empty housing
column with ps bos and steering shaft
like this with no axles
Old May 13, 2008 | 12:32 PM
gte718p's Avatar
I'd take it but shipping it to cali, would cost more then building it myself.
Old May 13, 2008 | 04:41 PM
88rnr86up's Avatar
all sold but chassis
$500 with ps steering,4 link,front springs
Old May 18, 2008 | 08:08 PM
88rnr86up's Avatar
anybody ??
offers trades??
Old May 28, 2008 | 05:07 AM
swamprunner1's Avatar
Tube chassis
Can you send me some more pics and details about the chassis. Who built it, tubing used ect. I'm on the outer banks so I guess I'm in striking distance. I have a built 4runner that needs a body and always wanted to build a buggy.
Old Jun 21, 2008 | 07:05 PM
88rnr86up's Avatar
sold already
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
shredder4286
Oct 1, 2015 01:09 PM
tylermx71
Sep 29, 2015 08:49 PM
toyotasaurus
Sep 24, 2015 03:30 PM
