1986 4Runner part-out
Old Oct 19, 2012 | 01:02 AM
Utah4Runner86's Avatar
Rear third and IFS box are not for sale. What I know for sure is:
7.5" front diff with 5.29 gears and a Detroit TrueTrac limited slip. The LSD has maybe 20 runs on it, 5 runs on the gears since a very good diff guy set them up. I think $500 is fair, but I'll entertain offers.
ECU for a 1986 22RE automatic. $25.
a340F automatic transmission and transfer case. $100, and if you need the driveshafts we can talk.
5 CV shafts. One is a nearly new NAPA reman I'd like $30 for, the others used and I want to get $20 each.
Grey interior bits are for sale, all of them I think. Dash, trim, seats, make me an offer. The drivers seat is rough, passengers seat is fair. Dash has two minor cracks. Carpet is nasty, you can have it if you want it. I've got two grey door panels in very good condition I'd like $75 for.
I've got an SR5 cluster from a v6/automatic, all the bulbs work, $50. I've got my old DLX cluster banging around too, I'll trade you it for a soda.
Nearly new (like, 1 week old) Doetsch Tech shocks from Low Range: 2 DT3336 - 26.50/15.50 EB1/EB1 and 2 DT3923 - 17.50/11.50 S1/EB1. $50 a pair.
IFS hubs, nuthin' wrong with them a little paint wouldn't fix. $75.
22RE alternator, power steering pump, and starter... $20 each? It's got a Compcams stage one cam, $25. The engine internals have maybe 20,xxx on a complete rebuild - the block is holed outside piston three, but everything else should be good. Make me an offer on any of it, the head, the valve train, whatever you need.
I'll sell the whole rolling schmear (blown motor and all) minus the bumpers and sliders, front diff, rear third, steering box, shocks, and hard top, and I think the roll bar is spoken for. It's a clear title. $300.
I also have a matched set of 4.30s, front 7.5 and rear 8inch ring and pinion. I'll sell the whole set for $125, or front or rear for $75 each.
I'll add more stuff as I decide what I'm keeping and what I'm getting rid of, and I can provide pics on request. If you're looking for something I didn't list, ask! I'll keep the post updated with anything that's sold. Trades are welcome - I'm looking for a Little Will or other good magnetic mount CB antenna, I need a 5.29 third locked or open, bushwacker flares to fit a 1st gen 4runner, a transfer case, duals adapter, shortened rear driveshaft, all the usual goodies.
I'll ship anything on your dime.
Sold:
Fuel tank sender
Passenger vent register
AC bracket bolts
SR5 cluster
Roll bar
rear window switch
Old Oct 19, 2012 | 06:30 AM
snobdds's Avatar
Can you take a picture of the dash pad...I want to be first in line on that.
Do you have the door handels, pictures? I know there are two differnt styles, that is why pictures will help me here.
Is the alt. and powersteering pump and starter OEM? If so I will take those.
Thanks
Old Oct 19, 2012 | 03:50 PM
Outsane's Avatar
Do you have power mirrors or windows?
Old Oct 19, 2012 | 05:11 PM
gottadog's Avatar
Passenger side grey vent shipped to 94568
Old Oct 20, 2012 | 01:37 AM
Thanks
I'll get a pic of the dash in the morning. Inside or outside door handles?
I don't know for sure if they're OEM, but I have no reason to think they aren't. If there's particular things about the OEM parts you're looking for, I'd be happy to check.
Old Oct 20, 2012 | 01:40 AM
I have another set of doors with power windows and mirrors that will be half-doors eventually. I'd be happy to pull them off those doors and sell them to you. I never hooked them up and don't know if they work, what do you think would be a fair price? $50 for the whole schmear, and I could probably fit it all in a $10 flat rate box?
Old Oct 20, 2012 | 01:42 AM
The outside one by the door? Lemme pull it in the morning and see what it'll fit in, but probably around $10?
Old Oct 20, 2012 | 05:46 AM
gottadog's Avatar
Yep the one by the door that is in the pad. If you would, take interior pictures before that part goes out. I may want other pieces.
Thanks!
Old Oct 20, 2012 | 07:08 AM
Sweet door panels that I never had the chance to install:
Dash:
Door handles
Cluster and cowl
More pics as necessary, just ask!
Old Oct 20, 2012 | 07:57 AM
gottadog's Avatar
Love to have the cluster as well. Was it adjusted for rpm? Direct plug in right? I've got an 87.
Old Oct 20, 2012 | 09:21 AM
It's factory adjusted for a V6, I never got around to making it read right for my 4cyl. It was a plug-in swap for me, but I was lucky and my truck happened to be pre-wired for the tach. If yours isn't you'd need to run a tach wire.
Lemme get that vent pulled and I'll see if I can fit it and the cluster in the same box. I'm procrastinating here.
Old Oct 20, 2012 | 09:27 AM
gottadog's Avatar
No problem dude, no rush.
Old Oct 20, 2012 | 04:18 PM
gottadog's Avatar
I just noticed it has the ect power normal lights on the gauge cluster0., darn. I'm gonna pass on it. .
Old Oct 20, 2012 | 11:02 PM
Outsane's Avatar
Sounds fair to me, and send me all the control boxes and wiring ya got
Let me know where to pay pal
Old Oct 21, 2012 | 01:53 AM
I'll let you know soon as I get 'em boxed.
Old Oct 21, 2012 | 02:10 AM
bob9's Avatar
are the door panels and dash still available?
Old Oct 21, 2012 | 05:00 AM
I'll put your name on the door panels. snobdds has dibs on the dash pad, I'll put you next in line if he doesn't want it or doesn't come back in a couple days. Did you want just the pad or the whole dash?
Old Oct 21, 2012 | 07:18 AM
gottadog's Avatar
PP sent for the passenger side vent.
Old Oct 21, 2012 | 07:33 AM
It'll be in the mail in the morning.
I updated post 9 with more photos.
Old Oct 21, 2012 | 07:43 AM
So, I apparently already pulled the drivers side regulator, and I can't find it. I've got the passenger regulator, both mirrors, and I'll send along all the harnessy bits I've got... $40 shipped?
