zero (o) offset wheel? vs stock
Old Nov 26, 2009 | 06:52 PM
elmerfudd_22's Avatar
A zero offset wheel would be pushed in further than stock right?
Old Nov 27, 2009 | 10:46 PM
I am looking at a rim that is 16x8 with 0 offset and 4.5 backspace http://www.americanracing.com/browse_atx.asp
compared to my stock 16x7 alloys, I cant find anything searching the forums with 0 offset how much of a difference would these be?
Old Nov 28, 2009 | 12:13 AM
Elton's Avatar
those will be perfect stock is 4 5/8" from what ive seen
Old Nov 28, 2009 | 01:12 AM
annoyingrob's Avatar
Offset and backspace are the same thing, just written differently. Offset is calculated from the center of the wheel, measured in + or - mm. backspace is calculated from the back face, measured in inches.
A 0 offset wheel means that the mounting surface is right in the center of the wheel. So if it was a 8" wide wheel, that would equate to 4" of backspace, not 4.5".
I have no idea what the stock offset is though. If it is 4 5/8 BS, that works out to about -28 offset.
Old Nov 28, 2009 | 05:40 AM
4Crawler's Avatar
Easiest to just stick with backspacing and width for determining how far out a given setup will stick out:
- http://www.4crawler.com/Diesel/Tires.shtml#WHEELS
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
1994toyota
Jul 17, 2015 03:03 AM
DrZero
Jul 13, 2015 09:59 AM
