Wrangler MT/R can only be mounted with white letters out?
Old Feb 1, 2011 | 02:12 AM
traxxi2003's Avatar
Ok, Hello everyone!
I need clarification on something, Yesterday I was about to order a set of four "Wrangler MT/R Kevlar" on 33x12.5x15. That was until the tirerack sales paerson stated that this tire, in this particular size are only offered with white letters side wall. He also mentioned that since they are "assymetrical" tires, they can only be mounted with white letters facing out. Is this true? I've seen other trucks in this forum equiped with the exact same tires, same size with letter facing in. What would happen if I were to install them black wall out anyway? Goodyear website does not offer any information on this. Can someone please explain? Thanks!!
Old Feb 1, 2011 | 03:40 AM
dropzone's Avatar
Fossilized
FYI-thread moved to correct section
Old Feb 1, 2011 | 07:50 AM
572ysc's Avatar
You can mount them with whitewall in. I went with the duratracs. I would recommend going with the duratracs, because they act like a highway tire and are much better in the snow(28" with my t100 this year without getting stuck). My other employee does wheeling and he had the mt/r and went with the duratrac, because they seem to last longer to.
Old Feb 1, 2011 | 08:23 AM
xxxtreme22r's Avatar
remember these tires are asymmetrical not just directional. Call BFG and ask them if you want to know for sure. I am pretty sure they make those as black walls as well.
Old Feb 1, 2011 | 09:05 AM
scuba's Avatar
BFG doesn't make Goodyear MTR's.
They are asymmetrical. However, there are plenty of reports across the internet of people mounting them with the white walls in with no ill effect.
But, IMHO, if your considering not getting a tire simply because visual reasons, maybe you don't need the performance of the MTR's.
This page shows which tires are white walled and which are black. Noted by the W or B at the end of each size.
BTW, these tires ROCK
Old Feb 1, 2011 | 09:19 AM
mightymouse's Avatar
this!
Old Feb 1, 2011 | 09:31 AM
haha thanks scuba for the I needed it. lmao. oops once again.
Old Feb 1, 2011 | 01:12 PM
traxxi2003's Avatar
Ok! I appreciate eveyone's input to my question! Now can someone share their experience with these tires? Like, How many miles c assuming you have a proper an you expect to get out of them? Assuming you have a properly aligned truck and with proper rotation/balance?
Thanks again to everyone!
Jose V
Old Feb 1, 2011 | 02:25 PM
scuba's Avatar
I'm thinking I should be able to safely get 50K miles out of mine.
After 5K miles, I had maybe 1/64th of an inch of wear on the front tires. The rears are another story due to the rear lockright. I think I had 1/32nd or 1.5/ 32nd's of wear. The tires will now be rotated every 3-3500 with every oil change.
A plus about these tires is they don't seem to chunk on the corner side lugs like I've seen happen to almost every set of KM2's I've laid my eyes on.
Old Feb 9, 2011 | 12:23 PM
89YOTAA's Avatar
yes i had a set of these on my cherokee (33x12.5x15) and i had the same problem. when they showed up i learned they could only go whites out. that was my plan anyway so it wasent a big deal. i loved everything about those tires and would def recomend them. they pulled through mud and crawled rocks with ease. also they worked very well at about 12 psi on the trail
Old Apr 11, 2011 | 06:42 PM
yotaduck's Avatar
I was hoping to hear this!
I picked up a set and was told that they had to be white out, but went against their word and told them to put black out(black truck, black wheels, hate white letters ), which they did. A few days later I noticed my sidewalls had started to slice. The tire shop ordered me 4 new ones to replace them, I'm banking on it just being a manufacture defect...
Old Apr 11, 2011 | 07:00 PM
scuba's Avatar
Pictures?
Old Apr 11, 2011 | 07:14 PM
yotaduck's Avatar
Driver front:
Driver rear:
Passenger side tires are still perfect. ~3 weeks old, driven maybe 70 miles. 285/70/17
Old Apr 11, 2011 | 07:41 PM
scuba's Avatar
I'm banking on a bad batch more than inappropriate mounting.
Old Apr 11, 2011 | 08:17 PM
yotaduck's Avatar
That's what I was thinking/hoping. It hasn't got worse since I noticed and I am taking it easy(pavement only for a bit) until the new set arrives.
Thanks for the help Scuba.
Old Apr 12, 2011 | 02:51 AM
91 4Runner's Avatar
Don't you mean 3/64?
Old Apr 12, 2011 | 06:44 AM
scuba's Avatar
Sure. But the tires are spec'd at 19/32'nds instead of 38/64'ths.
Old May 1, 2011 | 11:24 AM
yotaduck's Avatar
Just an update, new tires have been on for a few weeks now. I haven't got a chance to try them out on dirt just yet, but I've had no problems on the road. Still black out.
runnermedic
13
Sep 21, 2015 05:20 PM
JHalcyonM
Sep 14, 2015 01:10 AM
LJR
Sep 5, 2015 06:02 AM
pplusent
Sep 2, 2015 11:56 PM
Ryall
Sep 2, 2015 06:48 AM
