Old Apr 21, 2016, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
Print Wikipost
What PSI (pressure) are you running?
Old Mar 16, 2010 | 07:41 AM
  #121
Jazdude64's Avatar
Just installed LT24575R16 Goodyear Wranglers that are E rated. Running them at 65psi as per stated on the tire for load capacity.
Old Mar 27, 2010 | 08:49 PM
  #122
Jazdude64's Avatar
After thought and response to some emails I received, I aired down to 45psi... Gonna try that for a few days and see how it goes...
Old Mar 27, 2010 | 09:15 PM
  #123
yotaman85's Avatar
I have 30/9.5-15 A/T's, run them at 50psi all around. rides like a truck, they way its supposed to. and i still run around 10-12 psi when wheeling..
Old Apr 4, 2010 | 06:42 PM
  #124
Nimyad's Avatar
35 12.50 km2's 15 psi front and rear
Old Apr 4, 2010 | 08:46 PM
  #125
runnerboyy's Avatar
On the trail? or street?
Old Apr 4, 2010 | 09:17 PM
  #126
87hillbillyoter's Avatar
k i got a question. my tires say 50 PSI cold, and its snowing here and i have em at 40 psi. why are there different psi's for different temps? they are 31x10.5 Mesa A/T
Old Apr 6, 2010 | 07:56 PM
  #127
Nimyad's Avatar
on the street. 81 pickup
Old Apr 6, 2010 | 08:18 PM
  #128
yotaman85's Avatar
the difference between cold and hot: the tires are "cold" before you drive on them, as you drive the friction of the ground and radial flex (sidewall flex) will cause heat and there for make the tire "hot".as they heat up it will increase the pressure. you should try to set your pressure after a good time after sitting, or when they're "cold".
Old Apr 6, 2010 | 08:29 PM
  #129
ah thank you i thought it meant the air temp. i run mine at 40 psi for gas mileage
Old Apr 7, 2010 | 07:25 AM
  #130
runnerboyy's Avatar
..... why?
Old Apr 7, 2010 | 03:42 PM
  #131
Nimyad's Avatar
Talking
..... why?
don't drive very far every. max speed of 40 to wear i go. rides soft.
Old Aug 3, 2010 | 02:04 PM
  #132
Timbo's Avatar
35 on 295's
Old Aug 3, 2010 | 10:12 PM
  #133
az4x4runner's Avatar
Around 35 psi also in my 31x10.50 BFG M/Ts.
Old Aug 7, 2010 | 06:04 PM
  #134
giguchan's Avatar
The Procomp all terrain tire on my 97 4runner it says to inflate to 80lbs is this correct? the tire size is theLT 265/75R16 16"rim Load range E. I see you guys are running way below what it says on the tire it self. I have been running35-45...LBS.. i'll stick to the lower pressure.
thanks.
Old Sep 6, 2010 | 01:30 PM
  #135
hogman73's Avatar
265/70/16 yokahama geolanders i run at 32 psi. and i get 19.5 on average if i behave. Thats alittle city and rural driving mixed
Old Sep 6, 2010 | 09:44 PM
  #136
myyota's Avatar
What tire presure do you recommend for 37x12.50-15 MTR`s ?, right now i have them at 25 psi, how low can i air them down ?.
Old Sep 6, 2010 | 09:52 PM
  #137
85gijunk4x4's Avatar
depends on what day of the week it is...i re-air my tires to 35ish psi every monday morning, but by sunday night they are around 10-12 psi...sometimes i air up twice a week, depending on how bad my tires decide to leak
Old Sep 7, 2010 | 11:10 AM
  #138
Nimyad's Avatar
depends what your doing. a few friends of mine run the mtr's and in the snow, offroad they are them down to 4 psi or lower and in the rocks around 12-15 psi.
Old Sep 9, 2010 | 12:45 PM
  #139
greatskiiiier's Avatar
whats everyone running for a 12.5" wide tire on a 7" rim? im at ~27 right now
Old Mar 11, 2011 | 06:42 PM
  #140
wifes4now's Avatar
i just changed the 4runners 265/75r16s D
from 35psi to 45psi to see if it helps with the MPGs
