Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
- Toyota 4Runner, Tacoma, and Tundra: Why is the Tire Pressure Light On?
Guide to diagnose trouble and recommended solutions.
What PSI (pressure) are you running?
#128
the difference between cold and hot: the tires are "cold" before you drive on them, as you drive the friction of the ground and radial flex (sidewall flex) will cause heat and there for make the tire "hot".as they heat up it will increase the pressure. you should try to set your pressure after a good time after sitting, or when they're "cold".
#134
The Procomp all terrain tire on my 97 4runner it says to inflate to 80lbs is this correct? the tire size is theLT 265/75R16 16"rim Load range E. I see you guys are running way below what it says on the tire it self. I have been running35-45...LBS.. i'll stick to the lower pressure.
thanks.
thanks.
#137
depends on what day of the week it is...i re-air my tires to 35ish psi every monday morning, but by sunday night they are around 10-12 psi...sometimes i air up twice a week, depending on how bad my tires decide to leak
#138
depends what your doing. a few friends of mine run the mtr's and in the snow, offroad they are them down to 4 psi or lower and in the rocks around 12-15 psi.
