Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
- Toyota 4Runner, Tacoma, and Tundra: Why is the Tire Pressure Light On?
Guide to diagnose trouble and recommended solutions.
What PSI (pressure) are you running?
#63
Chalk test the tire:
1. Take some chalk and draw a line ACROSS the tread of the tire.
2. Drive about 50 feet, get out and check the line wear.
2a. Line is worn on inside the tire is over inflated, line is worn on outside under inflated.
3. Adjust pressure till entire line is evenly worn away.
Coincidently running about 10lbs less than what the max pressure is, is usually the number you will come up with.
Remember the more pressure the better mpg but stiffer the ride. Less pressure= less mpg.
#64
#65
I run 45 front and 50 rear in 265/70 16 BFG A/T's..65 psi max..BFG said that they recommend these pressures for my Tacoma..I had some weird vibrations @ 55 mph if I run less than these pressures.. The tires are wearing evenly too..
#70
i run 32 lbs in a 265/75/16 ...anything more than that and it kills ride and makes the truck jump around a good bit over bumps. i guess that's what i get for running a D load range tire on a truck designed for a C load range.
#76
if you're running over 40 psi, how can you stand it on the road? i cann't keep the tires on the ground with 35 psi ...much less with 45 to 50!
i'm running 265/75/16 nittos in a d load range. ....even though is says you can put up to 60 psi ...that's too much for a runner or a tacoma. ...i took mine down to 30 psi for a month and they still wore evenly ...
i run them at 32 psi on the road. ..off road, 15 psi
#80
Running above the recommended seems to be the key to better fuel economy. A lot of sites like www.gassavers.org recommend running up to the maximum. I reckon I won't do that but I do around ~38PSI in my 4Runner these days, It's above the Toyota recommended pressure but well below the tire maximum. If it's good for 1-3MPG then that's huge because when you're running btw 15-18MPG then a 1-3 increase isn't bad.
Some light reading..
http://www.officer.com/article/artic...on=19&id=27281
http://www.gassavers.org/showthread.php?t=803
Driving Under Pressure
Proper Tire Pressure Could Save Your Life
Posted: December 22nd, 2005 02:41 PM EDT
Courtesy Bobby Ore Motorsports
SGT. DAVE STORTON
EVOC Contributor
Officer.com
How many officers check the tire pressure on their patrol car on a regular basis? We all seem to be great at checking that the lights and siren work, because the time to find out they don’t work is not when you get a Code 3 call. Likewise, the time to find out your tire pressure is too low is not when you are in a pursuit and trying to take a corner at high speed.
What is proper pressure?
The proper tire pressure for the Police Crown Victoria is 44 psi. If you look on the sidewall of the tire, you will see that it lists 44 psi max pressure. Regardless of what vehicle you have, use the maximum pressure listed on the sidewall. Higher pressure results in better performance, decreased tire wear, and it lessens your chance of hydroplaning at a given speed. This number on the sidewall lists “the maximum amount of pressure you should ever put in the tire under normal driving conditions.” Pursuits and Code 3 responses are not “normal driving conditions.” Many agencies maintain tire pressure at 35 psi since this is what is listed in the owner’s manual and on the door placard. The reason the owner’s manual lists 35 psi is because we get the same manual as the civilian version of the Crown Victoria. The police version, however, is fully loaded with communications equipment, a cage, and your gear. You are not looking for a soft and cushy ride, you want performance.
Myths about pressure
Let’s put to rest some common misconceptions. The tires will not balloon out creating a peak in the center portion of the tread when tire pressure is above 35 psi. There is a steel belt that prevents this from happening. Also, you are not overstressing the tire with higher pressure, and the tire will not be forced off the rim with higher pressure. The picture above is Bobby Ore of Bobby Ore Motorsports driving a Ford Ranger on two wheels. The tires on the left side have 100 psi in them, and they happen to be tires and rims from a 1999 Crown Victoria! This is a dramatic example of how pressure holds the tire in shape, and how much stress a tire can handle.
Performance
If you were able to watch a tire as it travels across the ground at high speed, you would see that it deflects to one side during cornering. The faster you are going through a corner, the more tire deflection you get. As the tire deflects over onto the sidewall, you get less traction and more of a tendency to understeer or oversteer. This could spell disaster when negotiating a corner at high speed during a pursuit or a Code 3 run. Higher pressure keeps the tire from deflecting onto the sidewall as much, which keeps more of the treaded portion on the road.
A good demonstration for EVOC instructors is to have students drive a high-speed course in a vehicle with 32 to 35 psi. Then have them run the same course with 44 to 50 psi in the tires. The student will experience a marked difference in performance. Having officers experience this difference in vehicle performance is much more effective than just telling them to check their tire pressure.
Hydroplaning
When a tire rolls across a road covered with water, the tire tread channels water away so the rubber remains in contact with the road. The factors that affect hydroplaning are speed, and water depth. Conventional wisdom says that vehicles will hydroplane in as little as 1/16th of an inch of water. Not so coincidentally, legal tread depth is 1/16th of an inch.
Tire manufactures and the Association of Law Enforcement Emergency Response Trainers International (ALERT) have shown that tires have more of a tendency to hydroplane when pressure is low. This happens because the tire footprint (the portion of the tire actually in contact with the road) is larger. For those of you who water ski, think of which is easier to get up on: a fat ski or a skinny ski. More tire surface in contact with the water makes it easier to hydroplane, just as it is easier to water ski on a fat ski. Also, a soft tire can be pushed in more by the pressure of the water on the center portion of the tread. This results in less rubber in contact with the road.
Tire wear
Much better tire wear results from maintaining proper pressure. Tires with lower pressure will wear off the outside of the tread faster from the deflection of the tire during cornering, and the tires will heat up more from increased road friction. This is one of the factors that caused the failure of a certain brand of tires on Ford Explorers some years ago. In 1999 the San Jose Police Department realized a significant cost savings by increasing the pressure in the training fleet to 50 psi. They soon followed up by increasing the pressure in the patrol fleet to 44 psi. For liability reasons, most agencies are reluctant to exceed the maximum pressure listed on the tire for actual patrol vehicles, but they reap the cost saving when going to 50 psi on training vehicles.
Next time you inspect your vehicle, make sure you check your tire pressure since your ability to performance drive is significantly affected by it. You are not driving to the store to get a loaf of bread! You may be called upon to chase a dangerous criminal or respond to assist another officer in trouble. You don’t wonder whether or not your gun is loaded before you hit the street; don’t’ wonder whether your tire pressure is correct once the pursuit starts. Check your tires routinely, just as you do with all other critical equipment.
SGT. DAVE STORTON
EVOC Contributor
Officer.com
Performance
Hydroplaning
Tire wear
