Tire Pressure at 26/29 or 32?
Old Feb 25, 2005 | 11:37 AM
argonzero's Avatar
Hello everyone,
I just bought some 265/75/16 Bridgestone Dueler A/Ts and was wondering should I keep my tires at 26 front and 29 rear as it says on the door of my Tacoma 2004 double cab or go with 32 PSI. The guy at the shop says 26/29 but im not sure it'll contact correctly on the ground. Anyone have experience with this?
Old Feb 25, 2005 | 11:55 AM
I have 29-30 all around, and the revos feel pretty soft. I might bump it up to 32 or 35psi, maybe do a chalk test
Old Feb 25, 2005 | 12:17 PM
rimpainter.com's Avatar
35 for street use on mine. 265/75/16's here.
Old Feb 25, 2005 | 12:40 PM
99runner4me's Avatar
That's what I use on mine too. 285/75/16 tires though.
Old Feb 25, 2005 | 02:09 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Ditto what 96 Runner said (pressure and size). Plus, I'll air down to about 26 for deep snow. But it's really a matter of personal preference and varies from tire to tire.
Old Feb 25, 2005 | 03:18 PM
Ironmike4x4's Avatar
At my dealership we are told to air it at manufacturer's specs mainly for ride quality. But I've always aired my at least 5 psi below cold tire specs for both gas mileage and handling.
Old Feb 25, 2005 | 03:28 PM
p5150's Avatar
you will get better mileage with a higher tire pressure
Old Feb 25, 2005 | 11:47 PM
argonzero's Avatar
What PSI does everyone think would create less uneven wear on the tires?
Old Feb 26, 2005 | 04:06 AM
Rick F.'s Avatar
If you're experiencing uneven wear, you need to make some repairs, either suspension, alignment or both.
Old Feb 26, 2005 | 04:32 AM
Bumpin' Yota's Avatar
You should have just enough air pressure to get all of the beads to wear evenly. If the inside bead wears the most, then its over inflated. If the 2 outermost beads are worn and not the inners, then you are under inflated.
40psi in my BFG ko's 235/75r15s LRC
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
itzmywife's
Jul 25, 2015 04:55 PM
skoti89
Jul 8, 2015 12:05 AM
