Rim Width vs. Tire Width
Old May 14, 2009 | 10:17 AM
LGRECO81's Avatar
Question Rim Width vs. Tire Width
So i got new Wheels - Brand new Rock Crawler 15x10 on craigslist. ($150 for 5 which I thought was a steal)
I'm gonna put 33" tires on them but am unsure as to the width restrictions I am facing. Can I put a 12.5 on a 10" Wheel?.. If not what is the widest I can get on there?
THANKS
Old May 14, 2009 | 10:25 AM
95RunnerSR5's Avatar
you'll be fine with a 10" rim. i think thats what is recommended anyways. i ran an 8" wide rim with 12.5" wide tires and they were fine too
Old May 14, 2009 | 10:45 AM
Tubbyfatty's Avatar
You can run just about any tire on any rim as long as the tire is wider then the rim.
There is alot of info about this in the "tire and wheel" area on here. Go take a look if you want more info.
Old May 14, 2009 | 11:13 AM
toyota4x4907's Avatar
I've read that typically you want to stay within 4.5" of tire-rim ratio, ie, no more than a 10.5" wide tire on a 6" rim, etc.
Old May 14, 2009 | 11:16 AM
Junkers88's Avatar
*laugh* The tire being wider than the rim doesn't even matter, crazy lowriders.
OP. You'll do just fine with 10" wheels and a 12.5" tire.
Old May 14, 2009 | 11:26 AM
GSGALLANT's Avatar
If you can find one, I'd like you to post the specs of a tire that they recommend mounting on a rim that's wider than the tire.
Old May 14, 2009 | 11:47 AM
LGRECO81's Avatar
Thanks guys! I'll most likely go with a 12.5
Old May 14, 2009 | 12:06 PM
Junkers88's Avatar
Originally Posted by GSGALLANT
If you can find one, I'd like you to post the specs of a tire that recommend mounting on a rim that's wider than the tire.
Never mentioned anything about recommended. Most lowriders and bombs around here run 155/80/13's (6.1" wide) on a 13x7 rim (7" wide).
Rim
http://crite2000.zoovy.com/product/W...Wire_Rims.html
Tire
http://crite2000.zoovy.com/product/T..._LOWRIDER.html
Old May 14, 2009 | 12:17 PM
mrmatson's Avatar
I run a 12.5 tire on an 8in rim so you'll be just fine withe the 10in rims.
Old May 14, 2009 | 11:32 PM
space-junk's Avatar
its called running a stretched tire...
http://media.photobucket.com/image/s...C2419_copy.jpg
http://media.photobucket.com/image/s...P1010030-2.jpg
it actually looks pretty cool...
its a way of getting away with a wider rim to fill the wheel well without having to pay mondo cash for a new set of tires...
Old May 14, 2009 | 11:36 PM
abecedarian's Avatar
well, those low-pro tires aren't cheap either...
and if you run out of gas, you can wind some string around the rims and pull from the driver's seat to get the car down the road instead of getting out and pushing.
Old May 15, 2009 | 01:04 AM
ovrrdrive's Avatar
I wouldn't run anything less then a 12.5" tire on a 10" rim to completely avoid the look posted in the pics above... A tire needs to be sucked in a little to look right. I hate it when the sidewalls are less than flat.
Old May 15, 2009 | 02:46 AM
GSGALLANT's Avatar
Rim
Tire
Just because people do it, it doesn't make it's right (or safe). Manufacturer recommendation for tires that size would be to mount it on rims between 4" and 5" wide.
Jun 1, 2021 01:51 PM
chukarhunt
Dec 8, 2019 11:39 AM
4x4-runner
Dec 27, 2016 01:58 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
Yotoder865
Jul 9, 2015 07:51 PM
