Rim Width vs. Tire Width
So i got new Wheels - Brand new Rock Crawler 15x10 on craigslist. ($150 for 5 which I thought was a steal)
I'm gonna put 33" tires on them but am unsure as to the width restrictions I am facing. Can I put a 12.5 on a 10" Wheel?.. If not what is the widest I can get on there?
THANKS
THANKS
You can run just about any tire on any rim as long as the tire is wider then the rim.
There is alot of info about this in the "tire and wheel" area on here. Go take a look if you want more info.
I've read that typically you want to stay within 4.5" of tire-rim ratio, ie, no more than a 10.5" wide tire on a 6" rim, etc.
If you can find one, I'd like you to post the specs of a tire that they recommend mounting on a rim that's wider than the tire.
Rim
http://crite2000.zoovy.com/product/W...Wire_Rims.html
Tire
http://crite2000.zoovy.com/product/T..._LOWRIDER.html
http://media.photobucket.com/image/s...C2419_copy.jpg
http://media.photobucket.com/image/s...P1010030-2.jpg
it actually looks pretty cool...
its a way of getting away with a wider rim to fill the wheel well without having to pay mondo cash for a new set of tires...
its called running a stretched tire...
and if you run out of gas, you can wind some string around the rims and pull from the driver's seat to get the car down the road instead of getting out and pushing.
I wouldn't run anything less then a 12.5" tire on a 10" rim to completely avoid the look posted in the pics above... A tire needs to be sucked in a little to look right. I hate it when the sidewalls are less than flat.
Never mentioned anything about recommended. Most lowriders and bombs around here run 155/80/13's (6.1" wide) on a 13x7 rim (7" wide).
Rim
Tire
Rim
Tire
Jun 1, 2021 01:51 PM
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
Dec 27, 2016 01:58 PM
