Question about car wheel having part of car rim sticking out beyond fender line?
Old May 9, 2017 | 11:58 PM
hammer34's Avatar
Hi, all! This question is about the stability of the wheel rim (resilience to fracture/breaking) under the following circumstances:
1> When there is say 4-5 cm sticking out of the fender line(fender line drawn from front to back of car), ie when we look at the car from the top the rim has about 5 cm sticking out! If the lug patter is say 11.5 cm 5 bolt type, then increase
the dia of the central bolt areas' dia to say 20 cm (for example! in a 16 inch dia rim).
2> This bigger area sticks out by 5cm from fender line, viewed from front to back.
What are stability considerations for such a car rim which would resemble a truck dually rim, which has a part sticking out? Would making dual phase steel thickness: 6-8 mm make it a feasible design, and make the rim, roadworthy.
Thea idea is to use the truck dually rim design to a car, what thickness dual phase steel (approximate) would make such a design feasible, thanks,
dropzone
1546
Mar 23, 2021 09:06 PM
swampedout
Jul 16, 2018 02:25 AM
mdwreckdiver
Jul 20, 2017 03:31 PM
Matt16
Jan 7, 2009 03:19 PM
