Need A little Help & Info?
Old May 19, 2009 | 06:25 AM
YotaRolling's Avatar
Hey guys i have a stock 1990 4runner 3.0l Auto i am a gear head so what can i say anyways i want to put 33" tires. I would like to know what the stock running ring and Pinion. Second what gear ratio is the best i live in washington state so i have hills i have to deal with. This is my frist yota, are the 90-95 v6 motors all gutless. i just did a Jspec motor swap my last one went tits up so i got a used 50,000 motor from my local import shop and when i get it the injectors were smaller then the one on my older motor any issue there? thanks blake
Old May 19, 2009 | 06:34 AM
UKMyers's Avatar
Welcome to Yotatech. Please utilize the search feature. How to determine your gear ratio is asked here every single day it seems. A simple google search even would have given you several websites that break down the code on your door jamb. There is not just one ratio for that year. Your experience here will be much better if you put a little bit of effort into researching your information rather than just asking general questions that have already been covered hundreds of times.
As far as what gears to go with that is a age old debate. With 33's people will argue over 4.56's or 4.88's. I ran 4.88's with 33X12.50 BFG's for 4 years and loved the combo.
Old May 19, 2009 | 05:30 PM
Here's the break down of what i was looking for.
I have a stock 90 4runner 3.0 auto.
I have been doin research and haven't found what i have been looking for. Here what i am looking for and seeing if you you guys can help me out..
I want to put 33" tires, so i would like to know what gear ratio would be good for a daily driver. I live on in the Washington so i have alot of hills around me.
So with that in mind i was wondering what kind of rpm your running at doing 80 miles per hour pulling a hill.. and also with that same gear ratio you are suggesting what kind of mpg are you getting at that kind of speeds, freeway and in city.
thanks you guys for you help!
Old May 19, 2009 | 05:41 PM
Ardent's Avatar
80 miles per hour up a hill with a 3.0l Auto? Throwing the shennanigans card again. Well, I guess I got close this weekend. I was climbing up to about 7,000 ft at about ~75mph I was running about 4200 RPMs. I have 31's and 4.56 gearing (according to axle code, not verified).
Hope that helps.
Old May 19, 2009 | 07:30 PM
the resin i say 80 because the free way speed head to my exit to head home is 70 so incase i have to pass someone or what ever i would like alittle more power... then just doing the speed limit....
Old May 19, 2009 | 07:40 PM
UKMyers's Avatar
Guess you have not driven your rig lately. What he meant is you'll be lucky to hit 80 going downhill let alone uphill. Also like I said earlier if you ask 10 people what gears to go with your going to get a bunch of different answers. I'd run 4.88's if it were me IF I knew I was never going to run a bigger tire. I have regeared my rig twice now.. should have just done 5.29's the first time around.
Old May 19, 2009 | 08:05 PM
gary96360's Avatar
i have 33 swampers and i bet theyre heavy as 35 a/t and its not that bad on 4.56 gears but i have a 5 speed. for 33's u need like 5.29 gears for the auto
TheBFA
Feb 15, 2020 06:55 AM
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
buckz6319
Aug 5, 2017 03:50 AM
White Stripe
Oct 6, 2015 10:47 AM
dirk89
Oct 1, 2015 05:15 PM
