Looking for a vendor who can actually align and balance 4runner tires in Denver metro
Old Oct 21, 2007 | 01:30 AM
Wife's 4runner's Avatar
Hey, I really miss my old shop back in Vancouver, Wa. Now I am here in Parker, Co. Sure enough I let Discount tire rotate the tires. They now vibrate-when I had vibration free tires for a blessed 6 months. So, who is the best in town? I have little confidence in Discount. So...thoughts?
Old Oct 21, 2007 | 06:03 AM
OSU4Runner's Avatar
I would take it back to the shop and make them redo the work until they get it right
Old Oct 21, 2007 | 09:02 AM
sdstud212001's Avatar
There is a macjine that most doscount tires have called road force balancing, I would ask for that.
Old Oct 21, 2007 | 10:01 AM
Djlarroc's Avatar
Yeah, welcome to CO! I would also take it back to discount and have them redo it. If they can't get it right, get a refund and go to 4wheelparts in Aurora. How big are your tires?
Old Oct 21, 2007 | 06:36 PM
Tires are stock on 16inch rims. I will go back to discount who will tell me... "well, they are not our tires so we can't really guarantee it" at which point I will lay down on the floor, kick and scream and demand satisfaction!"
Old Oct 21, 2007 | 10:02 PM
Or get your $$ back, if they cant do the job then you shouldn't have to pay. Unless you paid for an unbalance service.
Old Oct 21, 2007 | 10:10 PM
DeathCougar's Avatar
How does rotating the tires cause vibration? Even if it were the case, it would not be Discounts fault. You may have other issues with your truck, or just may need a rebalance.
Old Oct 22, 2007 | 12:29 AM
Knuckles's Avatar
The design of the wheels used on the 4Runner are different than most. They are not “hub centric” meaning the hole in the middle of the wheel is not in the exact center. You will never ever get the wheel properly balanced using normal tire balancing equipment. Normal tire balancing equipment uses the center hole to mount the wheel to the tire-balancing machine.
The Toyota wheels used on the 4Runner are “lug centric.” This means that the lugs are the center of the wheel and the lugs must be used to balance the wheels. To do this a special adapter that engages the wheel lug holes must be use in conjunction with a special back side forcing cone to properly mount the wheel to the tire balancing machine
http://www.4runners.org/writeups/haweka/index.html
Try a Toyota Dealership in Denver.
Old Oct 22, 2007 | 07:09 AM
Pretty straight forward, the tires in the rear wear different then the front. The 4runner is the most sensitive on the planet to such things. Discount failed to rebalance because they thought the very same thing and just threw them on. Thus I have out of wear tires.
Old Oct 22, 2007 | 02:58 PM
roundhouse's Avatar
Isnt there some kind of special adapter thats required for yotas?
Old Oct 22, 2007 | 03:16 PM
Knuckles's Avatar
umm... yeah i posted about it , ABOUT TWO POST UP.
http://www.gadgetonline.com/Vibration.htm
https://www.yotatech.com/forums/f123...lancing-41788/
here is someone who went to discount tire also
http://www.tundrasolutions.com/forum...b-lug-centric/
Old Oct 22, 2007 | 03:20 PM
traben27's Avatar
Um...did you ask them to rotate and rebalance them...because you can have either of them or both of them. I dont mean to make you sound stupid or anything, I'm just making sure.
BushPig
Oct 29, 2022 06:26 AM
Jun 1, 2021 01:51 PM
87blyota
Jul 8, 2015 09:16 AM
skoti89
Jul 8, 2015 12:05 AM
