Help - Super Swamper LTB's
Old Apr 6, 2004 | 12:25 PM
grafix43's Avatar
im looking into getting these tires in the 34x10.50x15 size but i need help with ttwo things. first of all on the interco website under rim size it says 15x8.5, so does this means these tires will only fit with a 15x8.5 in rim?? cause i have 15x8's in the front and 15x9's in the back so im wondering if the tire will still fit these.... second thing is i found them at natl tire for 120$ each but then thats 50$ for shipping so total is like 530$... anybody know of a place i can get them for cheaper? thanks - steve
Old Apr 6, 2004 | 01:11 PM
kyle_22r's Avatar
if you have a local 4wheelparts they should have them in stock for around 120 or so
seeing as these are only 10.5 wide tires, i'd probably use a 7" rim or possibly a 6" rim. 9 is going to be way wide on them
Old Apr 6, 2004 | 08:24 PM
grafix43's Avatar
7 or 6 in rim? i would think that is way too small. i called interco earlier and she said that the websites says 15x8.5 as that is the suggested rim width. she did say it would fit 8 in and 9 in wide rims, just suggesting that 8.5 is the best to go.... anybody else have any info they can help out with?
and btw the way, even though its a 34x10.50, the specs on the website said overall diameter was 33.6 inches, and the width mounted on a rim was 11.2... so if that helps any let me know - steve
Old Apr 6, 2004 | 10:03 PM
kyle_22r's Avatar
i've heard reports that it's more of a 33" tire. i would definitely not run them on 9" rims, as they would pop the bead very easily on the trail.
also, the general consensus is that these are great cheap trail tires, but terrible on the road and wear very fast
fountain
Feb 28, 2016 10:13 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
93RedKrawler
Sep 29, 2015 02:50 PM
nerofiend
Sep 22, 2015 07:17 AM
