Correct tire pressure? 4x4 tacoma 265/75/15
Old May 7, 2004 | 06:15 PM
baileymoto's Avatar
I do not have an owners manual. I have 265/75/15 tires on a 99 4x4 xtracab tacoma. any idea what my tire pressure should be?
Old May 7, 2004 | 06:48 PM
Nitro Hotpants's Avatar
it should tell you on the inside of your door jamb. and im guessing around 32 PSI
-Casey
Old May 7, 2004 | 07:13 PM
nightsurfride's Avatar
On the side of your tire is a MAX PSI. A good rule of thumb (to minimize tire wear) is to fill them 2 psi under the max. Now obviously if your max is 80, then 78 might ride a bit hard, so 60-70psi is what I useally rec. I have 65 psi as my max and I put 60 psi in them. Rides fine and makes the tires last to there fullest potential, (as far as tire press. is concerned)
BushPig
Oct 29, 2022 06:26 AM
jbv808
Aug 6, 2021 04:47 PM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
HRDC0R19
Jul 5, 2015 06:43 PM
