BFG ATs true size?
Old Dec 24, 2007 | 04:45 PM
RoBatt's Avatar
BFG ATs true size?
anybody know if BFG ATs are the true size as listed ive heard that some tires that are for example 35s arn't true 35s. thanks guys
Old Dec 24, 2007 | 05:57 PM
Trustyrusty's Avatar
Most tires aren't FYI
Old Dec 25, 2007 | 05:10 AM
FredTJ's Avatar
Virtually NO radial tires are.
Fred
Old Dec 25, 2007 | 05:25 AM
nix4x4's Avatar
Most tires are usually .5" to 1" smaller than they advertise
Old Dec 25, 2007 | 05:29 AM
FredTJ's Avatar
Once you get to 30's or so it's more than that.
For instance, most 35's run (mounted on the vehicle) about 33"...
Fred
Old Dec 25, 2007 | 05:48 AM
James Dean's Avatar
Most companies have a chart that shows actual tire diameter. I know BFG does. http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
Old Dec 25, 2007 | 06:03 AM
FredTJ's Avatar
And I can tell you that the chart is only correct for an unmounted tire, laying on it's side and maybe even flattened a little.
Mounted and on the vehicle it isn't even close.
Fred (also here in Tucson).
MERRY CHRISTMAS !!!
Old Dec 27, 2007 | 09:23 AM
RoBatt's Avatar
well the whole reason im asking this question to begin with is because i see a 4runner with a 4inch ifs lift and 35 inch bfg ats on it and if the bfgs arn't "true" size and i put a different kind of 35 inch tire on my runner and it being way to big because it istrue size. does that make any since? here is the runner im talking about and thats what i want to do to mine just different tires
Old Dec 27, 2007 | 11:53 AM
toyotaman11's Avatar
for most of the tire mfgs. the tire size is smaller than the size on the side wall - but interco ( www.intercotire.com ) the company that makes sawmpers the advrtised size is the actual size . or within an inch or so. they also have one of those charts on ther site too.
Old Dec 27, 2007 | 12:08 PM
RoBatt's Avatar
so is interco the only tire manufacturer that is like that
Old Dec 27, 2007 | 12:32 PM
emptypockets's Avatar
When shopping for 285's, I looked at the Trxus M/T. 285's are supposed to be equivilant to a 33x11.50. IIRC, the Trxus is 32.7 x 11.2...one of the smallest 285's I found. The tires I ended up buying (Wild Spirit Radial TXR II's) measure 32.8 x 11.3.
Old Dec 27, 2007 | 01:14 PM
FredTJ's Avatar
Originally Posted by emptypockets
<SNIP>. The tires I ended up buying (Wild Spirit Radial TXR II's) measure 32.8 x 11.3.
Mounted and on your vehicle with all the weight, they measure 32.8" from top to bottom, correct ?
Fred
muddpigg
Nov 2, 2015 05:36 AM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
