33's on stock 93(I KNOW IT WILL RUB!)
Old Mar 25, 2021 | 11:03 PM
Asho0883's Avatar
Hey i've always read forums and stuff but I finally need some insight from someone lol. I currently have 31x10.5s on my stock 93, but I got some 33x12.5 because who cares. Anyway I don't care if it rubs... all I wanna know is how much lol. My torsion bars are cranked to the max already. I'm gonna cut the pinch weld obviously etc. So anyone know just like how much rub i'll be getting? It's a pavement princess too so now worries abt off-roadin. If heard just so many mixed feelings abt the rubbing? So it it actually THAT BAD? Like I can still drive right lol... Just not as tight right :p
Old Mar 26, 2021 | 03:22 AM
rattlewagon's Avatar
Youll be fine. The backspacing on the wheel will determine how much of the tire gets stuffed into the fender when flexing.
Old Mar 26, 2021 | 05:56 AM
MaK92-4RnR's Avatar
Put em on and find out.
Old Mar 26, 2021 | 07:24 AM
Mk_98's Avatar
15x8 wheels 3.75 back spacing
Old Mar 26, 2021 | 12:14 PM
moto809's Avatar
5 Year Member
My 31x10.5's rub on my 93 with 1" ball joint spacers if I get crossed up enough. I don't see how 33x12.5's wouldn't be a constant battle, but as MaK92-4RnR said, put em on and find out.
Old Mar 27, 2021 | 08:02 AM
highonpottery's Avatar
How tall is the front suspension with the torsion bar lift you did?
I have a 93 and wanted as little lift as possible to clear 33x12.5. My suspension ended up measuring 22.5” from center of axle to bottom of fender.
Wheels are 15x8-3.75bs, I have 1.5” bj spacers and some stock tbar adjustments, as well as pinch weld clearancing with a BFH and bumper trimming, and no sway bar.
Rear is the same height 22.5” with OME leafs, stock shackles and triangulated shocks (u-bolt flip); rear is the only place my tires still rub - at the rear of the bed fender near mud flaps, but only when I have some weight in the bed and I’m fully articulated.
I already had the BJ spacers on and some tbar adjustment- but to get tires to clear, basically I just drove my truck up a rock at the bottom of my driveway so I could flex the suspension as much as possible, while turning, to see where it would hit and then marked it and started adjusting tbars and then the pounding and trimming
Old Apr 15, 2021 | 06:40 AM
sametoce's Avatar
Rubbing Issue
I agree with you. So did it rub?
zebra_machine
Feb 29, 2008 06:14 PM
littlewhiterunner
Feb 24, 2008 06:05 AM
creeve4
Jul 20, 2007 10:16 AM
scubasteve83
Jan 4, 2004 07:39 PM
wimpywade94
Jun 27, 2003 11:22 AM
