33/12.50 on 3 inch lift.
Old Jan 5, 2010 | 02:37 PM
85yota4x4's Avatar
does anyone have a picture of 33/12.50 tires on a 3" spring lift?
Old Jan 10, 2010 | 12:47 PM
85yota4x4's Avatar
bumpp
is anyone running this settup?
Old Jan 10, 2010 | 02:31 PM
hiltu's Avatar
33x12.5x15 procomps on a 3" rough country lift
Old Jan 11, 2010 | 06:54 PM
85yota4x4's Avatar
will i have to take off the metal piece thats under my bumper to make the tires fit?
Old Jan 11, 2010 | 07:01 PM
MaK92-4RnR's Avatar
you have a 3" lift... try it out. you can make 33x12.50s fit stock if you really wanted to.
Old Jan 11, 2010 | 07:02 PM
4Crawler's Avatar
Here's my '85 originally 3.5" lift and 33x9.50 tires:
- http://www.4crawler.com/4x4/4R_suspension.shtml#Epilog
Had to do a fair bit of work to get those tires to fit w/o rubbing including trimming fenders, I never had the front valence on the truck, 1" body lift ar the tires w/ no rubbing:plus I ended up moving the axle forward ~3/4" to finally cle
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseII
Old Jan 11, 2010 | 07:56 PM
85yota4x4's Avatar
how does it sit on flat gound. not under flex
Old Jan 11, 2010 | 08:01 PM
4Crawler's Avatar
Old Jan 11, 2010 | 08:38 PM
85yota4x4's Avatar
ok thanks for the pics, so it looks like i will be okay, but pretty soon i will either be doing a 2 inch body lift or shackles
Old Jan 11, 2010 | 08:58 PM
ISLANDER 80 CRUSHER's Avatar
here is mine on stock and 2 inch body lift to fit 305x7016 same as 33's
Attached Thumbnails 33/12.50 on 3 inch lift.-forsale-016.jpg   33/12.50 on 3 inch lift.-forsale-020.jpg   33/12.50 on 3 inch lift.-forsale-022.jpg
Old Jan 11, 2010 | 09:01 PM
85yota4x4's Avatar
ok well im mounting my new 33/12.50 km2's on some new 15x8 cragar soft 8's tomorrow so i will get pics up right away
Old Jan 11, 2010 | 10:44 PM
big2003viper's Avatar
so i'm about to get an 85 toyota pickup 4x4 with the originol suspension on it and i want to put a rough country 3" lift and 31 inch tires on it. Does anyone have pics of a yota with this lift and tire size combo so i have an idea of what it would look like?
Old Jan 12, 2010 | 07:34 AM
85yota4x4's Avatar
i have 3" tuff country with 30 inch tires
Old Jan 14, 2010 | 03:26 PM
blcktpgsr's Avatar
if i have atleast a 2.5" lift, will it be free from rubbing issues if i mount a 305/65/17's?
Old Jan 14, 2010 | 03:27 PM
blcktpgsr's Avatar
if i have atleast a 2.5" lift, will it be free from rubbing issues if i mount a 305/65/17's? its for a 97 4runner..
Old Jan 14, 2010 | 03:36 PM
Hayes's Avatar
That's what I run in the front...
Old Jan 14, 2010 | 05:05 PM
desertcamper67's Avatar
You probably will have to remove the valance under your bumper unless you get a little lift. Most of your rubbing is going to be on the rear of your tires turning or flexing. Mine did just turning into slightly sloped driveways. Even with shackles and a 3 inch lift I had rubbing. Fixed that one with a 2 inch body lift.
Old Jan 14, 2010 | 05:10 PM
blcktpgsr's Avatar
so more than likely i have to add another inch or so bodylift, what about just slapping a 1 1/4" spidertrax spacers in addition to the 2.5" lift? will that resolve the issue? perhaps goin' down in tire width size..
Old Jan 16, 2010 | 08:47 PM
Originally Posted by Hayes
how bad is your steering with the lift since you have the stock steering setup?
Old Jan 30, 2010 | 11:59 AM
yotafreak!84's Avatar
was wondering about a 98 sr5 if 33x12.5r18 would fit with 2 inch suspension lift? just bought some rockstars 18x9 with 0mm offset... any recommendations on tire size and brands? was thinking mtz's or the km2's
