32X11.50 BFG All terrains
If the rim sticks out farther then stock, you will have rubbing issues.
If you want to go with a wide wheel setup, go with a 10.50" tire, or if you want a wider meat, lift the truck or beat the inner fender to clear.
hell yeah, do it up i lovee mine.
except its a 93'......
you might have to do a little bit of "modification" to the front bumper, but trust me its worth it.
I run 32x11.50 on my 94. I have steel rims that are a little wider than the stock rims. I had some rubbing until i took my running boards mud flaps and front bumper valence (plastic piece) now i'm all good. i can get full turning on flat ground with no rub. if i have a wheel up in the air and turn hard it touches but this is prob cause i need new shocks.
Go for it! They are a great tire size
I have had both, 32x11.5 and 33x10.5
I had rubbing with the 32x11.5, but no rubbing with the 33x10.5
Both are great tires, love the BFG A/T KO either way.
You can't go wrong with either, the 33x10.5 is the more popular of the two on this board, it gives you more ground clearance and because they are narrower you will get more pizza cutter effect than the 32x11.5 ie. you may see advantages in snow and mud. I really like my 33x10.5s. My 2cents!
nvwiggins
13
06-16-2016 03:05 PM
FS[GreatLakes]: 33x12.5x15 bfg ko a\t
muddpigg
11-02-2015 05:36 AM
94toyy
12
09-14-2015 06:18 AM
