Staging Area For Tech Article Submissions Got a tech article to submit? Post it here
Horn Relocate for 2nd Gen Tacoma
Old Dec 12, 2012 | 12:54 PM
Benson X's Avatar
Post Horn Relocate for 2nd Gen Tacoma
Another way to relocate your horns.
I needed to free up space behind the grille for the hidden winch I will be installing. I didn't want to move them behind the fuse box, since I might install the winch control box there.
STEP 1:
Disconnect the battery.
STEP 2: Remove the grille.
STEP 3: Unplug and remove the (2) horns & unplug the sensor from the middle pillar.
STEP 4: Undo all the retaining clips from the wire-loom. You can re-use the locking clips (Zip-Tie style) by prying up the lock tab with a small flat-head. Strip off all the tape and conduit up to the battery/headlight area.
STEP 5: Separate the Sensor wire from the (2) Horn wires (Light Gray and Dark Gray).
STEP 6: Cut the (2) Horn wires and strip the ends off each.
STEP 7: Mount the horns.
Here's where I decided to mount each horn.
Driver's Side: Next to the radiator
Passenger Side: Next to the radiator
I used the factory holes to run a bolt, lock-washer, washer, washer, then nut to hold the horns.
Here are the holes I used:
Driver's Side
Passenger Side
I loosened the bracket on each horn so I could position them where I wanted, then tightened it back up. After they were where I wanted, I tightened the nut on each of the bolts.
Here's what they look like mounted.
Driver's Side:
Passenger Side:
STEP 8: I measured a length of wire to the passenger side horn, and soldered it to the Light Gray wire and plug. I trimmed the excess length of wire from the Dark Gray wire and soldered it back to the plug. I used heat-shrink tubing on each of the solder joints, and wrapped the whole thing with conduit and electrical tape.
I used a Zip-Tie on this hole to keep the conduit tucked up (there was another hole to use, but didn't want to sacrifice it in case I used it in the future)
STEP 9: Plug everything back in and re-connect your battery and honk your horn. Have a beer to celebrate another successful mod.
FINISHED PRODUCT
Rasteirinho
Nov 6, 2017 03:40 AM
landrunner
Aug 5, 2015 09:18 PM
jimkoz26
Aug 5, 2015 03:15 PM
vanion2
Jul 29, 2015 06:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
