Domestic Swaps Chevrolet, Ford, ect
Why does everyone go with a chevy or ford smallblock??
Old Oct 10, 2008 | 05:31 PM
  #41
baseballchamp157's Avatar
350's give a good bit of torque. With some low gears and some 38s, you shouldnt have any problems crawling, mudding or any offroad touring. theses guys dont always have the money to reinforce and change the whole drive train to put in more torque. its just more money efficent. It all coms down to money, knowledge, parts, and what you want the truck for!
Old Oct 14, 2008 | 04:57 PM
  #42
Cargun's Avatar
Huh? Small block Chevy is a high revving engine? That's a new one. You're probably confused by all the high performance versions that are out there. The 'classic' 350 TBI had 300 ft-lbs at 2800 RPM and redlined around 5000. The 350 Vortec has 330 ft-lbs at 2800 RPM. B-body LT1 has 330 ft-lbs at 3200 RPM. All so close to your quoted numbers for the Olds engine there is essentially no difference.
If you want more torque, just throw in a longer stroke crank.
327's have the same bore as as 350, but a shorter stroke, making them a less torquey motor. (I've heard people refer to the 5.3 as a 327, which is incorrect. The 5.3 does have more low end and high end torque than a Vortec 5.7, but less mid range torque.)
Old Oct 14, 2008 | 11:38 PM
  #43
khoopes's Avatar
What a thread. You would think we were racing the big 3 again...
If I HAD to do an engine conversion... I'd put in a turbo diesel. Can you imagine 4 cyl. 3.0L Cummins or something similar? Lots of torque and what a fuel miser..
Old Oct 15, 2008 | 05:56 AM
  #44
Adam F's Avatar
Yea...but 4bt's arent cheap, and parts arent dime a dozen and readily available. Plus they are HEAVY and vibrate like a mo-fo! Would be a cool swap though. MPG is mid to low 20's, from what I understand. That can be accomplished with a SBC beleive it or not.
I did my 350 swap for the fact that the SBC is cheap, parts are cheap and easy to come by, power is good, and they sound cool!
Old Oct 15, 2008 | 06:20 AM
  #45
saitotiktmdog's Avatar
I second the diesel Idea. The new cummins QSB3.3 has 85-110hp and 215+lb torque. There are others as well int he 3 to 4 liter range that would fit nicely into a toyota. Look for them in tow motors and other similar applications. With a few mods too you could easily get more.
Old Oct 15, 2008 | 06:23 AM
  #46
They even have a marine app 4 liter that has 250hp. Oh and its a cummins, who needs spare parts. Those things last for ever. Well not really but you know what I mean.
Old Oct 20, 2008 | 06:00 PM
  #47
TrikeKid's Avatar
VW TDI swap would be a better way to go IMO. 30mpg (that's in a 2nd gen truck, they will pull 50-60mpg in the cars they come from), plenty of power and torque, and it's actually refined enough to have been factory in something other than a UPS van. If you really want to, you can build the later ones to upwards of 300 horses, and torque much beyond that, lots of aftermarket too. 90hp and 155 ft/lb stock in a small package. You can be pushing 200 ft/lb with minor tuning.
People already have the adapter to hook them to a Toyota transmission too.
Old Oct 27, 2008 | 06:43 PM
  #48
Trustyrusty's Avatar
Arguably the BEST domestic engine I have EVER seen is a Ford 300 Inline Six.. I had an old econoline with a 240 6 Popper, smaller version of the 300 and that engine had 240K on it, and it was ABUSED, hadn't had the oil changed in five years at one point in its life, dripped every fluid imaginable, burned oil, and coolant, but it was SOLID I woulda trusted that thing with my life.. I might eventually swap in a 300 I6 or a Chevy 350, Seeings as I have one and a nice set of heads, I never have liked chevrolet though, but you can't beat a 350, good solid engine, simple to build, lasts forever.
FYI I knew a dude who ran an offenhouser intake, split headers with straight pipes, big ass cam, and dual webers on his 300 and it out ran a brand new Camaro.. Hehe
Old Oct 29, 2008 | 12:54 AM
  #49
Adam F's Avatar
We have a ton of 300's and 200's in equipment at work. They are pretty tough, and they get abused every day. When they run right they are pretty torquey motors.
Old Oct 30, 2008 | 03:30 PM
  #50
the 300/6 has better torque then any 302. I personally think its the best motor ford ever came out with. chevy has 350, ford has 300/6, toyota has the 22r, dodge has the 318 mag.
Old Nov 22, 2008 | 04:36 PM
  #51
rev. chuck's Avatar
Originally Posted by 941uzfetaco
I dont meen to get hostile but dont call me dawg.I didnt say that the 350 and 5.0 dont have tourque I just dont think they have enough.Plus they were meant to be hi winding motors not lowend tourque engines thats all Im saying.
And I know theres crawlers on here and I dont get why they dont go for olds engines for the lowend tourque I guess Im just a crazy sob.
torque can be obtained by simply changing your intake
lets take the lt1 5.7 for example they fall flat on their face at 4800 rpm but will spin 15 inch truck tires on a 94 caprice station wagon for over half a block
if thats not torque well i dont know what it
this seems to be a case of dont know wtf your talking abouts
Old Nov 22, 2008 | 04:52 PM
  #52
Dr.Tonka's Avatar
if it lacks torque or power.....use gears to make up for it ! hell a suzuki sammy can 4x4 just fine and it has NO torque.
Old Nov 22, 2008 | 05:14 PM
  #53
rev. chuck's Avatar
i just sold a sidekick that i wheeled with street tires on it and it did pretty damn good
Old Jan 1, 2009 | 02:31 PM
  #54
kenbo53's Avatar
It may just be me but it seems that throwin one of these in your trucks dont make much sense.For one when you wheel you want torque not horsepower.Two they dont have a good lowend tourque even when modified (sp?).I would rather go the extra mile to for tourque than just buy a kit for a chevy small block.Personaly I'm suprised no one has dropped an olds v8 into one yet especially a 403 small block I would love to put one in a toyota considering they have 320ftlbs of tourque at 2800rpm stock.And for all of you who think it would be hard or expensive its not.The 403s used th350s,th400s, and the bolt pattern will bolt to the th-2004r which can use th350 mounts and fits where any th350 will fit.Plus the th-700r4 can be used behind it with an adapter plate.And the they make kits for axle swaps to handle the power,trans mounts for all but one trans selected,and trans to toyota transfercase adapters.All this leaves is a custom 3-4 core radiator,custom twin electric fan setup and shroud,a electric water pump,custom motor mounts,and custom headers.Plus with a few mods these motors will push more than 400ftlbs of tourque at only a few hundered rpm more.I dont know about you but I would love a toyota with that motor.
Not to be geting hostile or anything but my 1971 gmc's stock 350 cranks 350 lbs of torque at 3000 grand and 250 hp at 4600. However they havent built them that good since but the later ones are basicly the same thing cept for being packed full of power robing emisions equipment, and lower compression ratios. So if you want something cheap find a rebuildable 350 dump in some flat top pistons, a good troquey cam, tune up or replace ur carb and ignition and ull have more torque than ur toyata has room for. The olds would be sweet tho if ur willing to trade money and probly quite a few unforeseen complications just to have something off the wall.
Old Feb 8, 2009 | 05:45 PM
  #55
rockymountian yota's Avatar
all i have to say is a 350 in a toy is all you will ever need for anything and because its chevy, parts are everywhere and cheap.
Old Jul 31, 2009 | 10:16 AM
  #56
TK119's Avatar
Its cost why would u want a motor that runs you a bunch of bills to build as to where a 302 u can always find parts for and a 350 you can go buy performance parts right in most parts stores the last thing most people want is a wheeler that if it breaks u cant go find a replacement part for with out having to special order it... plus with a 4 speed with a granny gear on a 350 motor you could pull a two story house down no problem
Old Jul 31, 2009 | 07:42 PM
  #57
Adam F's Avatar
350 has no torque my ass.
With my 3.0, on 36's with 4.10's, I had to pin it in 3rd gear at 4500 RPM's just to maintain 65mph up a 25% grade.
Now with the 350, same 36's and 4.10s, same tranny, going up the same 25% grade, I can cruise in 5th gear at 2000rpm going 65mph with only a 1/4 throttle. Plenty of power in 5th gear to go as fast as I want.
And its got neck snapping torque off the line. This is a stock 350 with headers/carb/intake. Probably 200hp and maybe 300tq.
LittleUgly
15
Jan 2, 2020 01:30 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
JookUpVandetti
Sep 17, 2015 09:25 PM
