Domestic Swaps Chevrolet, Ford, ect
v8 swap 82 toyota
Old Jun 29, 2009 | 04:32 PM
stillblazed's Avatar
Question v8 swap 82 toyota
i got a 82 toyota and i wanna put a 350 in it what all do i need to do and what to worry about, thanks
Old Jun 30, 2009 | 12:37 PM
fillsrunner4's Avatar
Starts using the search function at the top of the page. also search the forums as theres an entire section on motor swaps. IMO the 350 is too big and heavy without doing mad amounts of fab and other work to have it as your powerplant. Another great option thats a chevy motor for you is the 4.3. better choice IMO into that truck
Old Jul 7, 2009 | 03:55 AM
HarryBCO's Avatar
Yeh i put a 4.2 Chev in my 80. Lots of work but hey at the end of the day lots of fun now its on the road
Old Jul 9, 2009 | 05:38 AM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
4.3 is just about the easiest swap for a Toyota, and the best bang for the buck.
Old Jul 27, 2009 | 01:50 PM
Nothingface5384's Avatar
if youre stuck on a v8, a buick 350 would be perfect!
it is about an inch wider/taller/longer then a 350 but it'll fit(same kit as buick 231/3.8 v6) the kicker is it only weighs 450lbs.
and if you want to convert to a serpentine setup you'd just have to get the parts for a gn setup.
but a chevy 4.3 will give it good performance without being overpowering
and unlike a chevy 350 both can be had used for low $$ more so on the buick 350..
Old Jul 27, 2009 | 07:51 PM
Adam F's Avatar
Originally Posted by Nothingface5384
and unlike a chevy 350 both can be had used for low $$ ..
Huh? A 350 is about the cheapest engine out there. Parts are a dime a dozen, readily available, and in TONS of cars and trucks in the junkyard. I've seen a few given away for free.
Thats what makes the 350 swap so desireable.
Old Jul 28, 2009 | 06:20 PM
around my area, chevy 350s go for 450 to 600(plenty for 500)
buick 350 you can find a 70-80k engine for 50 bucks to 150...just picked one up for 400 with only 23k on it
ive found plenty of 80k 4.3 for 150 to 250
was just stating you can fid both those engines for same milage or less for less cash
Old Aug 6, 2009 | 09:28 AM
BlueRidge's Avatar
Do your homework bro on that swap. A 1980 only has 31 inches of space from firewall to where the radiqtor mounts. I'm currently installing a 302 and it's tight, even with the short Ford Racing water pump kit it's a bitch to get it all in without fabricating/modifying anything.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
RaginAsian91
Jul 27, 2015 07:11 PM
thelifeadventure
Jul 2, 2015 03:09 PM
infinityisfive
Jun 16, 2015 06:51 PM
