Domestic Swaps Chevrolet, Ford, ect
Torque converter 2nd & 3rd lockup?
Old Feb 8, 2009 | 04:41 PM
texcat101's Avatar
With the swap I am doing I have the option of wiring my 700r4 torque converter with a switch that would allow me to lockup the T/C in 2nd and 3rd or 4th only at my choice.
I have been trying to get my mind around the value of the 2nd and 3rd lockup and am not sure I see many real world instances where it would be beneficial.
I know lockup creates less heat, so maybe extended driving in the lower gears like on mountain roads... has some value.
Am I missing something?
Old Feb 8, 2009 | 08:22 PM
okie81's Avatar
Well, you would think that the 2nd and maybe the 3rd lockup might be handy for passing, but if you floor it, you're gonna downshift anyways. I had a camaro with a 700R4 and the lockup was really touchy in 4th so it would be nice to be able to hold it in there when you needed to.
Old Feb 9, 2009 | 10:07 AM
texcat101's Avatar
I think I will wire it up for 2nd, 3rd & 4th on one leg and 4th only on the other and see how it functions.
I will post my results.
Old Feb 9, 2009 | 10:15 AM
okie81's Avatar
Either way you go, that's a killer option to have at the flip of a switch, good luck with that.
Old Feb 9, 2009 | 06:44 PM
91diesel's Avatar
I put in a relay with a floor switch in my Toyota auto (343f) for this option. I did it because I have a diesel and try to get really good mpg by going easy from stops. The high factory stall (2200 rpm) makes this a pita so I lock it up @ 15mph in 2nd and then shift through the gears keeping it between 1500-2100 rpm which works great for the diesel. The floor switch makes it nice to turn off and on easily in traffic.
Old Feb 10, 2009 | 11:09 AM
texcat101's Avatar
Nice! The way mine will be wired I will have 2,3&4 lockup in one position, I will watch what this selection does to the fuel economy... driven slow and easy.
I am installing an LED indicator so I will be able to tell what I have selected more easily. I like the floor switch idea!
Old Mar 31, 2009 | 01:39 PM
ffryno13's Avatar
where did you get this lock-up switch from. cuz i am doing pretty much the same set up as you i just havent decided on runnigh the stock ECU or using the mega squirt 2 system yet.
mskalmus
May 28, 2017 07:51 AM
izzmee
Aug 17, 2015 10:20 AM
129Creepin
Aug 5, 2015 10:12 PM
91yotapup
Jul 27, 2015 07:19 AM
Jnkml
Jul 6, 2015 01:20 PM
