The Swap is On! Toyota,Mercruiser and Chevy?
#122
The mercruiser intake doesn't have the coolant bypass fitting that comes on the automotive vortec, and my water pump has the bypass plumbing so I plumbed a bypass loop to provide a small amount of coolant flow to prevent hot spots during warmup.
It appears my heater still gets enough flow to work ok.
#123
You are sharp!! I didn't think anyone was going to notice.
#124
I have been tuning on the MSII, it's really waking up! I think I am going to enjoy this setup for a while.
It may need 35's or larger??
#126
what was the original power rating of the mercruiser motor? where do you expect to be with it? any chance you'll get her on a dyno in the future?
#127
The 4.3 mercruiser is rated at 220 hp, with the MSII, headers, .030 over pistons and some custom headwork I hope to be around 250hp.
I have a friend that has a docking type dyno for his racing operation but there is no chance I am going to pull the engine just to find out what it turns.
I have been tuning the VE tables and it's really waking up but I will have to get the acceleration enrichment tuned before I know what It will do.
#128
maybe i missed it...but...did you do all of the wiring by yourself..or did you buy a harness from somewhere...because im kinda changing my thoughts on a 350V8 and kinda want a 4.3 V6..i can get a carb'd one bored .060 over..with LOTS of other power adding goodies..for little less than $800..should be close to around 250hp the guy said..but its carb'd..i want EFI but i dont wanna have to go through all of the BS with all the damn wiring..i would rather have more of a plug n play type set up..lol
#130
thats what i figured...but since my dad and I have never done anything along the lines of swapping such a different motor..we dont know what to do..2 days ago we swapped motors in a geo metro..and it runs now..but..goin from a carb'd 22R to a EFI 4.3V6...that'll be a little bit more tricky..mechanical wise we can do..but we are not good with wiring..i can get a 199? Vortec V6 with e Aluminum intake manifold that says VORTEC and is all purty and stuff...only has little over 1,000 miles on..(donated to our auto shop from a wrecked 4wd jimmy) we have never used it for anything..and the teacher said he COULD let it go..(its kinda illegal) but i bet hew wouldnt let it go for cheap..and the Carb'd one i can get needs Heads and intake..i can get a set of stock heads with a High Rise 4bbl intake for it
#131
Hey camo31, Just swap it!
I have had alot of people ask why I chose to do the swap this way and mostly it was because I wanted to learn about programmable fuel and spark control systems.... I found a multiport injection system for cheap and said "I can do this" and researched until I got the big picture, then installed it and worked thru one system at a time.
Its been fun and worth it!!
#132
lol..bad thing is..this is my daily driver..so it needs to be as simple a swap as possible...which is why i will stick to carb'd..lol..really nothing electronic to deal with..so it will be a faster swap..and if problems pop up..i know its not faulty wiring..LOL!!!might convert it one day though..convert it to EFI i mean
#133
#134
yea..i dont do any high elevation trails..highest is MAYBE 1000FT...so yea..lol..i mainly want the added power for towing my 18ft nitro..cuz the 22R..does NOT LIKE DOING IT..lol..and im thinking maybe some disc brakes on my rear axle sometime soon..cuz it dont like stopping that much weight either
#137
well..electrical aint that hard..but the fact that it would take longer to swap in an EFI vortec V6...no..i want to make this as short as possible..because of 1.im having to bum rides off of friends and grandparents to get to school and work..2. prom is coming up at the beginning of april..and i am NOT riding with anyone..im DRIVING..LOL!!!!! also graduation, summertime, it'd just be easier to do the swap with a Carb'd V6 than an EFI one..thats all..but like i said..i probably will convert it to EFI one day
